Need help selecting between two budget 10" drivers
Old 16th March 2005, 06:49 PM   #1
percy is offline percy  United States
Default Need help selecting between two budget 10" drivers
Dayton classic 10". 295-315 @ www.partsexpress.com
and
MCM 55-1945 @ www.mcminone.com
T/S parms for the 55-1945 are:-
Qms 3.6
Qes .35
Qts .35
Vas 110 lt
Fs 26hz
Mag Wt 35oz
Xmax 5.0mm
SPL 89db
Watts 70W, 105W peak
This is for a 1.3 cu.ft vented(but could be sealed if needed) enclosure for a 3-way.
There are a couple of projects using the Dayton but I cant find any information on the MCM. Not quite sure if its intended for subwoofer duty or driver(woofer) duty. The specs look good but I have no idea how it sounds or the frequency response or the build quality. Although the heavier magnet and higer Qms/lower Qes make it attractive.
Any inputs appreciated! Thanks!
Old 16th March 2005, 07:38 PM   #2
ShinOBIWAN is offline ShinOBIWAN  United Kingdom
ShinOBIWAN's Avatar
Where's the TS for the Dayton?
If you want a sub thats good for ported use, the general concesus is that the lower Qts the better.
Using the good old FS/Qes you can determine a rough guide for suitability.
In this case 26(Fs)/ 0.35(Qes) = 74
What does 74 mean? Well any number under 50 is an excellent candidate for sealed application, a number over 100 is great for ported. Anything inbetween like this could be considered for either depending on requirements.
Personally I'd go with sealed or a TL but that's not to say that reflex isn't good when done well. Just my preference really.
Old 16th March 2005, 07:50 PM   #3
http://www.partsexpress.com/pe/pshow...number=295-315
http://www.partsexpress.com/pdf/295-315.pdf
The TS of the mcm dont add up. One or more of the qms, qes or qts is wrong. I have an email into mcm inquiring about that.
I'll probably try both (sealed/vented) and see what I like.
Old 16th March 2005, 10:28 PM   #4
RJ is offline RJ  United States
If the qes is correct for the MCM than the qts is .319
MCM
Closed - Box size = 1 cu. ft. F3 = 62 hz.
Ported - size = 1.7 cu. ft. F3 = 42.5 hz.
Dayton
Closed - Box size = 1.2 cu. ft. F3 = 53 hz.
Ported - size = 2.2 cu. ft. F3 = 30 hz.
Done with WinIsd.
Win Isd program is free;
http://www.linearteam.dk/default.aspx?pageid=winisd
Need help selecting between two budget 10" driversHide this!Advertise here!
My Loudspeaker Project: a 2 way transmission line. Phase 1: selecting drivers Bricolo Multi-Way 59 8th September 2017 12:59 PM
What drivers do you recommend.... On a budget lapoltba Multi-Way 14 21st January 2007 04:23 AM
selecting drivers iceblueorbitz Multi-Way 4 16th June 2006 10:45 AM
$1000 budget for drivers. SkinnyBoy Multi-Way 5 14th January 2005 12:35 PM
