Old 12th March 2005, 04:11 PM   #1
Default Do all compression driver diaphragms look like this?
http://www.tachyon.co.jp/%7Esichoya2...555/we555.html
Old 12th March 2005, 05:53 PM   #2
pinkmouse's Avatar
Pretty much. Why?
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 12th March 2005, 06:00 PM   #3
The surround construction looked pretty unique to me... Then again, I haven't seen very many of them.
EDIT: They make a compression driver that operates from 15Hz to 1kHz. :O
Old 13th March 2005, 05:57 AM   #4
What part of the diaphragm? That is a replacement for a Western Electric 555. It's the only one I know of besides maybe some of the Japanese exotic stuff that uses that 2 section diaphragm shape, but lots of the old Altec drivers have a tangential surround. More common is a simple dome with some sort of surround. Common surrounds are tangential, half-roll, diamond, and flat plastic of some sort.
Old 13th March 2005, 10:20 PM   #5
Advantages/disadvantages to each type?
Old 14th March 2005, 12:19 AM   #6
ShinOBIWAN's Avatar
Only with an appropriately sized horn.
For 15hz you'll only need one thats about, off the top of my head, 80ft long
Old 14th March 2005, 01:50 AM   #7
Just making a driver that operates that low boggles the mind. I wonder what the Fs is...
Old 14th March 2005, 03:49 AM   #8
BassAwdyO's Avatar
Send a message via AIM to BassAwdyO
All drivers operate that low. At least any will respond to that frequency. Its more a matter of efficiency and maximum output
The golden rule of DIY:
Build nice, or build twice!
Old 14th March 2005, 04:00 AM   #9
Yes, but a compression driver operating that low has an extremely low power handling.
Old 14th March 2005, 04:09 AM   #10
Actually, it would 'only' have to be about 39.3ft long. Exit of the driver is 130mm so that sets the throat, 15hz flair, M~0.7, 8'x8' mouth. That's one example. However if you went for a 7hz horn but kept the same mouth size, then you'd hit 84' in length.
1" compression drivers with 2" diaphragms 454Casull Multi-Way 24 9th August 2009 04:19 PM
Zen and Compression Driver Opus Pocus Pass Labs 3 10th September 2008 10:02 PM
ESL as a compression driver? tade Planars & Exotics 32 16th August 2007 11:30 PM
FS: Silver Iris Coaxial 15" driver pair (sans XO and compression driver) theAnonymous1 Swap Meet 0 24th April 2007 12:09 AM
dopeing the aluminium diaphragms of compression drivers? Puggie Multi-Way 13 12th September 2005 06:57 PM
Page generated in 0.12642 seconds (73.35% PHP - 26.65% MySQL) with 10 queries
