Old 10th March 2005, 09:17 AM   #1
bowdown is offline bowdown  Australia
Question cross over question
Is it possible to use a zobel impedence equalization ciruit and a series notch filter on the same crossover?? If it is possible, how do i implement the zobel and notch filter and the crossover togather. Any help would be great.
Cheers
Bowdown
Old 10th March 2005, 09:49 AM   #2
shusha is offline shusha  Croatia
shusha's Avatar
Send a message via ICQ to shusha
If this is some sort of standard parallel circuit (and it probably is!) you will use zobel on bass and notch on tweeter.
If you need zobel and notch on the same driver (which is less possible) I assume that notch will be placed in front of zobel. First notch in series with driver and then zobel parallel to driver.
Old 10th March 2005, 11:20 AM   #3
Im confused now...... these are the calculators im using and from the diagrams they both look like they are in parallel with the speaker.
http://www.carstereo.com/help/Articles.cfm?id=23
http://www.carstereo.com/help/Articles.cfm?id=36
please help me.........................
Cheers
Bowdown
Old 10th March 2005, 11:36 AM   #4
DonoMan is offline DonoMan  United States
Send a message via AIM to DonoMan
Yes, you can. It does not matter which comes first, whether they are series or parallel.
Old 10th March 2005, 04:20 PM   #5
Bill Fitzpatrick's Avatar
In this application, the RCL circuit in parallel with the driver should not be called a notch filter.
Anyway, use both as the car stereo site describes.
Old 10th March 2005, 08:12 PM   #6
shusha's Avatar
Actually, I haven't respond to this article at caraudio.com because I was a little confused whole afternoon. Now Bill gave me a little courage and somehow confirmed my knowlege about crossover network circuits.
I consider myself an intermediate, certainly not beginner.
Impedance equalizer circuits consists of an resistor and capacitor wired in series together and parallel to driver. It's purpose is to flatten impedance curve of the driver. Imp. eq. are often known as Zobel network.
Notch filter consist usually of an inductor, resistor and capacitor wired parallel together and in series with driver (usually tweeter). The purpose of notch filter is to tame pekas in driver response.
There is also a circuit similar to Imp. eq. with resistor added in series and it's purpose is to flatten imp. curve caused by notch filter itself. This circuit is called notch impedance compensator and it is wired parallel to driver in front of notch filter.
So, as I said I was confused by an article at carstereo which says that notch and zobel are practically the same thing and that notch is like zobel wired parallel to driver.
Am I missing something ??
Hi:) and a passive cross-over question BMWTurbo Car Audio 7 26th November 2011 12:00 PM
Cross-over question about impedance Jimmy154 Multi-Way 4 23rd March 2005 01:39 AM
Yet Another Cross-Over Question abpea Full Range 4 7th March 2005 08:52 AM
Linkwitz-Riley Cross over question rs1026 Chip Amps 2 27th August 2004 09:15 PM
No Cross Over! chris ma Multi-Way 27 3rd January 2003 01:53 AM
Page generated in 0.08741 seconds (72.56% PHP - 27.44% MySQL) with 10 queries
