I am planning a project of high quality A/V speakers. I have already bough 4 Vifa's M17SG-09-08. Now I am thinking about possible tweeters. I have the following requirements: - possible to cross around 2-2.5 kHz - forgiving to bad signal (PC) but showing the difference when better source is used - sensivity at least 90dB - not very expensive - shielded Myself, I was thinking about Vifa's XT25, XT19, a couple of Seas drivers or the neodyme Morel 40 and 44. I wonder what would be your recommendations? |
#2 |
I hear a lot of good things about the Seas 27TFF as well as the Morel MDT 33 (or is that 30)? The XT is reputedly more of a challenge as it is more fussy about the crossover. Look at the response - it doesn't rolloff as high as other tweeters, hence needs a higher xo point and/or steeper xo.
AUDIO BLOG | Bass integration guide My work: www.redspade.com.au web design studio |
#3 |
paulspencer: Thanks for your coments. I also have heard a lot of good things about the Seas tweeters.
Still the most interesting question for me is: Which tweeters would have a chance to forgive a bad quality signal (PC), while offering good sound when fed by a good source? Do you have any experiences like that? |
#4 |
In other words you want a tweeter that is a little forgiving, not a high revealing resolution tweeter. Sounds to me like a case for a soft dome tweeter. IME treble is more forgiving when the top end rolls off a little. I use eq so that at my listening position the treble rolls off, tapering down from 1.5k down to 20 k where at the top end it is -2.5db. I find a lot of lesser quality recordings are a little bright and have some treble added to vocals, which is annoying. You may find a pad on the tweeter reducing its level by say 2db will help.
| Little help needed - Vifa MG18 + Vifa DX25 - 2.5way | guitvinny | Multi-Way | 12 | 10th May 2009 10:18 PM |
| Vifa P17SJ and Vifa D27TG Large Bookshelf MTM | rwo | Multi-Way | 7 | 24th February 2008 04:47 PM |
| Page generated in 0.08198 seconds (68.78% PHP - 31.22% MySQL) with 10 queries |
