Old 8th March 2005, 03:59 AM   #1
uzziah is offline uzziah  Norway
Send a message via AIM to uzziah Send a message via MSN to uzziah
Default price/performance speaker cables
looking to put together some good speaker cables to connect my sonic impact t-amp (soon to be modified) to my paradigm titans. i'm thinking something to the effect of 14-16awg silver plated copper teflon wire. thoughts?
friends don't let friends have noise pollution
silentpcreview.com
Old 8th March 2005, 04:30 AM   #2
simon5 is offline simon5  Canada
Zip cord will be fine.
DIYaudio for President !
Old 8th March 2005, 04:40 AM   #3
homer09 is offline homer09  Canada
homer09's Avatar
you will get a million different opinions on this. just try a few different types and then tweak the one you like best until your satisfied.
Most people wouldn't know good music if it came up and bit them in the ***. - Frank Zappa
Old 8th March 2005, 05:06 AM   #4
Bill Fitzpatrick's Avatar
I second the zip cord motion.
I tried some other speaker cable one night and when I woke up the next morning my amplifier was gone.
Old 8th March 2005, 08:16 AM   #5
Gregm is offline Gregm  Europe
Try single core wire. The easiest to find and experiment with are enameled pure copper wire (typically 0,8 or 1,2 mm, depending upon the current flow) or the wire you suggest (although combining metals creates potential which may or may not suit your purposes). I hope the latter isn't going to set you back millions, btw -- if so, I withdraw the recommendation.
I would avoid multistranded zip cord as there is access to other wire that's also very cheap.
BTW, a good commercial cable is Nordost Valhalla. It's low iductance, lowish capacitance, thin ribbon conductors, teflon dielectric. At EUR: 3000 it's a steal
If you don't like it, you can always offer it to yr SO; it's more expensive than lots of jewelry out there
Old 8th March 2005, 04:51 PM   #6
Speakerholic
Cal Weldon's Avatar
I just don't get how people can spend a lot of money on something like cables. Have you run out of money for important things like better drivers, crossovers or cabinets? You know, things that can make a big difference?
I use 10 ga. 64 strand high purity copper that cost 40 cents a foot.
Anyone want to put their boutique cables up against mine? You'll either laugh or cry depending on your perspective.
Cal
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 8th March 2005, 04:55 PM   #7
DonoMan is offline DonoMan  United States
Send a message via AIM to DonoMan
I use cat 5
Old 8th March 2005, 05:14 PM   #8
protos is offline protos  Greece
protos's Avatar
I second the recommendation for enamelled thin copper magnet wire.Just get some decent size spiral wire wraps to thread it through for protection and add some decent connectors because the bare copper ends are going to tarnish and break when you use it often .For low current (15-20 watt amp + efficient speakers)you can use as low as .375 mm which is better.Don´t worry -I have compared it with my own MIT Shotgun 750 ( 1500usd !!)cables and on many points it was actually better sounding.
Another option is thin copper tape as adhesive type or on some air core chokes (eg Goertz)which is also very good sounding and has good bass. There is some extra hassle to make a decent looking cover for it.
Otherwise the next level up is the same but in silver.
Personally I don´t like the sound of multicore types.
Old 8th March 2005, 05:28 PM   #9
rcavictim's Avatar
Try and obtain a 50 foot interconnect from a GPU used to power a DC3. It contains four runs of welding cable with a copper cross section the size of your thumb and half a million fine strands so that it is really flexible. Take it apart and make your own phat cables. If not that then #16 or #14 zipcord works just as well too.
Old 8th March 2005, 06:55 PM   #10
Brett's Avatar
I used that for years on low power systems and it stood up well to a lot of expensive cables. I'm lazy and have tons of C5 so that's what I use a lot of the time.
But beware that a lot of amps oscillate with more than short runs of the stuff. I reckon it sounds awful.
New Zaph kit breaks price performance barrier Dave Bullet Multi-Way 7 30th November 2007 10:07 PM
Price / performance sweet spots preiter Solid State 0 9th January 2007 07:23 AM
IS this the cheapest and best amp in the world based on its performance and price? the_wonderchild Chip Amps 66 5th September 2006 02:54 PM
Page generated in 0.11611 seconds (78.19% PHP - 21.81% MySQL) with 10 queries
