I was recently fying on a plane with my brother when i pulled a little cheap headphones a little bit to hard and acidentaly stripped the insulation to just bare copper. I am just curious how much power do these things draw........ enough to harm electronics?? Any thoughts would be appreciated!!
#2 |
headphones rarely use uncoated copper even beneath the isulation. Typically it is coated with red green or clear varnish which insulates electricially. So is it really bare copper? better test with a meter(using the resistance setting test the wire for continuity with the plug).
Anyhow. I would suggest some electrical tape to cover over the bareness either was I think 1watt max is pretty typical for headphones....
The golden rule of DIY: Build nice, or build twice! |
| 40A 250V Schottky Power Diodes- Has anyone use in Power Amp to replace Diode Bridge? | dtm1962 | Solid State | 10 | 15th September 2011 07:38 PM |
| LTspice tool for power amp power supply component evaluation | andy_c | Software Tools | 2 | 23rd August 2009 05:10 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
| power output calculations, rated power and required power output | metebalci | Tubes / Valves | 7 | 22nd February 2004 05:49 PM |
| Page generated in 0.09064 seconds (68.37% PHP - 31.63% MySQL) with 10 queries |
