Old 7th March 2005, 10:03 PM   #1
Stocker is offline Stocker  United States
Lightbulb Screen in horn mouth?
I am thinking of a pair of horns for a full-range system in a house with small children who may be intersted in dropping things into the throat of the horn...
Will a screen or grill cloth over the mouth of a horn affect the output or sound of the speaker?
Jesus loves you.
Old 7th March 2005, 10:43 PM   #2
jeff mai's Avatar
Default Re: Screen in horn mouth?
Fear of punishment will certainly have a less deleterious effect on the sound than a screen and it will serve a multitude of other purposes later on.
Old 7th March 2005, 11:18 PM   #3
Fear of punishment is, trust me, part of the plan.
But that doesn't change the curious nature of kids! Hey, I wonder what will happen if I drop this little stuffed bunny down the hole in this big box...
If I were to make these, it would be a semi-permanent install due to the hassle of moving them for cleaning... hence the question.
After all, only goes so far.
Jesus loves you.
Old 8th March 2005, 06:30 AM   #4
I would mount that thingie in a way that it could be removed later on (when your kids are old enough to take care).
I don't know how its sonic impact actually is, there will be one for sure but I don't know how much.
But my imagination tells me that it won't be severe since it is placed where velocity is low and pressure is high. If you have a look at professional horn drivers then you will notice that some have fine screens at exactly that place.
Charles
Old 8th March 2005, 10:15 AM   #5
Isn't the other way around?
Mvg Johan
Old 8th March 2005, 10:34 AM   #6
baggystevo82's Avatar
Send a message via MSN to baggystevo82
At the mouth I would have thought so.
Steve
edit: unless you were on about putting a screen deeper inside?
Old 8th March 2005, 11:21 PM   #7
I am thinking of a screen to cover the whole mouth and driver area. Some have argued (with empirical evidence, no less) that a speaker grille is audible. My electronics are nowhere near good enough to show it up.
Jesus loves you.
Old 9th March 2005, 09:39 AM   #8
As was mentioned above I think, so long as you made it removable for when the kids weren't around and/or could be trusted to to damage them...
Steve
Horn mouth bubble size MaVo Subwoofers 1 25th February 2009 11:59 AM
Horn mouth venting to the floor Tyimo Full Range 8 22nd February 2008 06:53 PM
Horn Mouth Diffraction mefistofelez Multi-Way 11 14th October 2005 01:04 AM
rear horn mouth area big_kahunah Full Range 1 16th August 2005 01:35 AM
Horn speaker w/variable throat & mouth bbaker6212 Multi-Way 1 1st August 2003 07:27 AM
Page generated in 0.08596 seconds (80.61% PHP - 19.39% MySQL) with 10 queries
