Eton 11", but wich midrange and tweeter match
Old 7th March 2005, 08:03 PM   #1
ronning is offline ronning  Norway
Default Eton 11", but wich midrange and tweeter match
Hi
I just bought the Eton 11-581, and are planning to use them in a box simular to the duetta . However, I would like to use a different midrange and tweeter (the duetta uses eton for both).
I was thinking of using the scan speak w15 8530 with the vifa xt 25. The Cremona and Krell LAT are good examples of these drivers working togheter, but will they work with the eton 11"?
I listen to a lot of rock and roll. Are the scan speak 15w a bad choice for this kind of music? I have considered other drivers, like the ss18w, audax(kevlar and aerogel). Are these or other drivers a better choice for my taste in music?
PS. I don't want Seas drivers for this project, and Accuton are a little too expensive.
Also, in the duetta, the crossover point for the etons' are 120Hz, which I find a little low. How about 200-300Hz, is that way too high for these drivers in this box? Or will a higher crossover point sound better with the small scan speak, and my taste in music?
Old 8th March 2005, 11:57 AM   #2
inertial is offline inertial  Italy
(sorry for my english)
Hi Ronning,
IMO the latest audax HM 130 Z 12 ( Z 18) are EXCELLENT.
and NEO 3 PDR B.G. is similar to the er4, also excellent.
200Hz and 3000 Hz seems ok.
No match with others at similar price and much more .
regards.
Old 8th March 2005, 02:42 PM   #3
Paco is offline Paco  Spain
Default Some options
Hi Ronnin,
Well, if you plan to keep the lower cut frequency at 120hz the best option with your budget is the Scan Speak 18W4531G00 that can go that low perfectly and will match in sensitivity. It will be almost impossible to match the 15W8530 with the Eton 11-581 so I don’t think it’s a suitable option. I would also consider use other tweeter, I like very much the Morel MDT30S, that can go much lower than the Vifa XT25 and will handle more power (you will need good power handling capabilities on the tweeter as we are talking about a hight quality 3 way system). If you prefer a more “correct” tweeter I would use the Scan Speak 2905/97, but I think the Morel is more "jazz-rocker" while the Scan Speak is more classical... regarding the mid-woofer, if you like rock music you may prefer a hard cone instead of the paper cone of the Scan Speak 18W4531G00 so you should consider the Eton 7-360/37 HEX.
Best regards,
Paco
Eton 11", but wich midrange and tweeter matchHide this!Advertise here!
replacement for the Eton 19SD-1, ¾" tweeter? GOWA Multi-Way 0 2nd June 2009 11:52 PM
ETON Midrange zimjj Multi-Way 0 28th April 2009 01:37 PM
TB1 with Eton ribbon tweeter? Nickos Multi-Way 1 13th February 2009 11:23 AM
Wich tweeter (seas 27tff ) ? catalin Multi-Way 7 14th January 2009 12:38 PM
image dynamics cx62 + Eton 4-300 4" hexacone midrange npdang Swap Meet 0 2nd November 2004 12:25 AM
