Im modifying an existing crossover design and I start to think that something is going wrong.
The speaker Im modifying is the adire ht10 and im replacing the tweeter with a unit that can handle more power. The new unit is the bms 4540ND it have the staggering sensitivity of 114 db but a decent curve for a compdriver. I installed the unit and tested my way to a atennuation value of about -11 db. The impedence should be ....well the specs given by bms are a bit tacky but at the crossover point it looks like about 9ohms and with my resistors it should have dropped a little overall. Anyway thats not the problem I have,the crossover point sounds ok to me and the tweeter takes over nicely. The real problem seems to be a hump around 350hz that I had not noticed before...in the beta 10cx! At this point I cannot reconnect the acd1 that was originally supplied w this speaker,they are dead after a night at the theatre.So no way of testing the original responce. What I can think of as cause is A the new tweeter is messing up the existing crossover of the bassunit or B the killer gauss of the bms is changeing the responce of the beta just by its extra magnetic force. Any ideas?
thanks for reading. H.Honda Chico CA Land of the fooled |
#2 |
Hello? Can you hear me now?
| Tweaking B&W DM 602 s2 | zverina | Multi-Way | 24 | 4th May 2006 12:12 PM |
| what CD buy for tweaking? | LennyK | Digital Source | 0 | 29th July 2005 08:50 AM |
| adire acd1 replacement ht10 | holger honda | Multi-Way | 0 | 17th February 2005 12:37 AM |
| DIY Amp Tweaking | choatie88 | Solid State | 4 | 15th September 2004 10:16 PM |
| Page generated in 0.06490 seconds (66.64% PHP - 33.36% MySQL) with 10 queries |
