#21 |
Well for me, the choice would be easy. The Volt B2500.1 is a natural match for the ATC.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#22 | ||
Moderation is the keyword here, a little low end EQ and I can get a frequency plot that is similar to the TL line without the hassle of a larger box with a long line and also avoid building a couple of prototypes to ensure correct labyrinth layout and stuffing densities. I'm hoping to get a flat response down to about 30hz whilst maintaining high effeciency and avoiding large amplifiers. I suppose I could go down to 20hz flat if I wanted to but these are for music rather than HT. I can always augment the output with a large subwoofer for HT at a later stage for the floor shaking bass. Quote:
You wouldn't have any more info on the design your working on would you? Driver's, enclosures, loading, amp specs anything really. Sounds like we have many parallels is in our designs. Thanks, Ant |
#23 | |
Sound quality is always high though and I've very little bad to say about them except they don't work as well in a sealed design and the driver baffle recess's annoy the hell out of me since I can just use the old circle jig. |
#24 |
Aurum Cantus G2/PR170M0/HM170Z0, xover is essentially 400/4000. 45L for the woofers, F3 47Hz. I posted earlier about it below...I've been working on the final enclosures and have yet to go back and tweak the XO more. I'll be using about 60W per driver, although this is complete overkill, even on the bass really. Just gainclones for now...I might get fancier later. I'm using a MOX setup to prototype.
3-way Aurum Cantus, PR170M0 w/measurements Essentially, your design appears to be the next step up from mine...more expensive drivers at each position, and about another octave of extension. If cost were no object, I would definitely audition the ATC mid...it appears to be an amazing driver. As I said, I'm quite interested in your choice of XO. Do you think there is any mileage in me trying an all-pass to flip the phase of my drivers at XO, as opposed to inverting the mid? The idea of a truly (time and phase) aligned system is tempting... I think I have almost convinced myself to try all this out on a DCX2496.
#25 |
diyAudio Editor
Does the tweeter have the efficiency to keep up with the ATC Mid?
#26 | |
As to driver capable of doing what you requested this time.. that's a tough one.. I'd say look back at the offerings from Peerless (xxls) and Scan Speak. At one time P-Audio had a driver designed for this (TM-10). Then there is the "King" of the group: the Aurasound NS10-794-4A (linear x-max is down right disturbing for a 10 inch driver). They are pricey and none to efficient, but if you are making a "no-holds-barred" system, what the hell.. You WILL need a powerfull amp though (in terms of current primarily.. see below) In case you are wondering if this is the "best" there is - the Co. referred to here in 6moons seems to think so (and they do seek out the "best" regardless of price, and are using what appears to be the 15 inch version in their "Ultimate" design): http://www.6moons.com/audioreviews/magico/mini.html Like I mentioned b4, most homes in the UK will have serious "bass lift" starting as high as the upper 30's because of masonry walls. If your "flat" has this - then eq. may be less than you might think (and as a result may enable your proposed design with far less watt's required).
perspective is everything |
#27 | ||||
Looks like a great project you've got going on there. Perhaps I can pick your brains when I'm in the testing stages. Quote:
The only problem with all this is that it tends to spoil you, all the stuff you thought sounded great now sounds so so in a direct comparison. I have some Visaton MHT12 ribbons and TI100 mid/bass drivers in a passive 2 way and they sound dynamically retarted, meaning small & compressed in comparison. Yet without a side by side test they sound great Quote:
Its hard to say conclusively, you don't happen to have any phase plots do you? Quote:
I wouldn't recommend keeping it in the loop as the permanant crossover since its not the most transparent device but as a tool its unrivaled at its price. |
#28 | |
So are a good match and level matching should be close without too much use of the trimmers. |
#29 | |
#30 | |
| Page generated in 0.15652 seconds (84.20% PHP - 15.80% MySQL) with 11 queries |
