Old 16th August 2002, 09:39 AM   #1
Default What's lurking at the bottom?
Hardly a week goes by without a question about subwoofers, and the joy of extracting that last drop of low frequency information out of a CD, DVD , or LP, but, just what is lurking down at those low frequencies?
What would I miss if my subwoofer only went down to 40Hz? Is there much of anything in the way of music or movie sound effects lurking at 30, or even 20Hz, that makes it an imperative that a speaker or subwoofer goes that low? Off the top of my head, I guess fans of pipe organ music would find something to interest them down at 20Hz, but what about the rest of us?
Thanks,
Glenn
Old 16th August 2002, 01:31 PM   #2
mrfeedback's Avatar
Hi Glenn, normal pracice in pop/rock DAW recording and mixdown is to virtually chop any content below 40-50 Hz.
For many such recordings this allows usefull multi-band compression and levelling without objectionable artifacts and wasting/overloading of LF playback system power.
Classical and other genres of course tend to a flatter and more actual LF rec/pb response.
Movie soundtracks are open to any effecting that the sound producer feels like, including very heavy compression/limiting of the LF band.
For typical home HIFI/HT application, so long as you have clean, dynamic and reasonably high power LF capability, you are unlikely to miss very much.
A clean and dynamic LF band system that goes reasonably low, can give a decent impression of low lows, without annoying the neighbours too much.
It takes a more seriously high powered system to reproduce high SPL low lows, so a degree of band limiting can be practically useful.
I believe horn or corner systems can give serious high SPL/low distortion LF replay, but require large dimensions.
NP has threatened to release details of a 20Hz horn CRAW system, but it is still in development it seems - Nelson we are waiting in anticipation .
On my high power, high resoloution workshop system I find a graphic eq to be quite useful for fine tuning of the system sound and compensating for differing recordings.
Sometimes when I feel like it I can patch in a compressor/limiter box to attain clean quite seriously loud SPL without system overload.
Clean, high power, transient capable and non-resonant are the keys to big, punchy, fat and pleasing lows - the downside is that this can be expensive.
Regards, Eric.
Eric.
Old 16th August 2002, 01:42 PM   #3
mrfeedback's Avatar
Default Noisey Neighbours.
Further thoughts - typical modern resonant/bandpass type subwoofers produce rotten/bonky/woofy/single note type bass that actually does not go properly low, and the resonant characteristic produces an irritating type bass sound that travels.
More than once I have telephoned a neighbour across the street and politely infomed him that his movie soundtrack although not playing very loudly, is a PITA at 2.00 AM.
In his lounge room his system does not seem all that loud, but the sound that propagates in the quiet night can be disturbing.
Much better IMO is a full range loudspeaker system that goes low and clean enough, and without resonant augmentation.
Eric.
Old 16th August 2002, 07:18 PM   #4
Some movie soundtracks have "silly" levels of very low bass. Lord of the Rings being the latest with many <10 Hz passages at fairly high SPLs. It's the first time my dual sealed Tempests bottomed out!
For most everything else, something that goes cleanly to 25-30 Hz is fine.
Pete
Old 20th August 2002, 04:56 AM   #5
Glenn:
Are you building this for home or PA use? It sounds like home use, but that 40 Hz cutoff you are considering makes me wonder.
PA equipment must be more efficient to produce greater sound levels. The sacrifice is bottom end. Most 97 or 98 dB @ 1M/1W PA cabinets of 3 cu ft have a cutoff of 60 Hz, for instance. A home speaker of 3 cubic ft would certainly be expected to go deeper much deeper than that. The payoff for the PA speaker is 8 or 10 dB @ 1W/1M sensitivity.
The lowest note on a bass guitar is 42 Hz. For that reason, a speaker that goes down that low is doing an adequate job.
If you have ever listened, however, to a subwoofer that has high output down around 20 Hz, you will notice that there really is a whole world down there, even in music. A friend had a system that went down below 40 Hz. He added a big subwoofer, and found that even his classical LP's from the 60's had substantial output down below 40 Hz, despite what the magazines told him.
The difference is there, and it is palpable.
40 Hz is good, but there is a reason people make the investment and effort to go lower.
Old 20th August 2002, 09:17 AM   #6
I simply chose 40Hz as an arbitrary figure, since with the exception of a pipe organ, there are no musical instruments producing anything down there. I figured movie explosions may have extended that low, but wondered what else was lurking below 40Hz.
I always intended to build a subwoofer for my system, for the benefit of movies, if not music, but it's interesting to learn that musically, there is something happening at those low levels.
Glenn
Old 20th August 2002, 11:32 AM   #7
griff is offline griff  Australia
griff's Avatar
Once you have a subbie for music you will never go back.....
griff
Old 20th August 2002, 12:47 PM   #8
mrfeedback's Avatar
Once you have a stubbie and music you will never go back.....
eric
Old 20th August 2002, 03:14 PM   #9
Default More below 40Hz
The fundamental of the A at the bottom of a piano keyboard is 27.5 Hz. Obviously we mostly hear overtones, but that note is there! Think about how much longer those strings are than those on a bass guitar. And don't forget that contrabass sarrusophone, too (whatever the heck that is).
Seriously though, harps go below 40 Hz (and play some great stuff there) and some pianos (Bosendorfer Imperial Concert Grand) have 96 keys and go to 16.35 Hz.
Bob's yer uncle.
Vince Harris
Old 20th August 2002, 04:13 PM   #10
diyAudio Moderator Emeritus
roddyama's Avatar
Hi Glenn,
There are two aspects of music that are often over looked. Those are Sub-Harmonics and "Differential" waves (for the lack knowledge of the correct term). These sound components exist in the lower octaves (some below 40Hz) and will be part of the character of the music.
Sub-Harmonics (f/2, f/3,...) of the fundamental frequency exist (at lower levels) as part of the total sound produced by instruments. There's info on the web if you do a search on "Sub-Harmonics". Here's one link:
http://www.phys.unsw.edu.au/~jw/sound.spectrum.html
Differential waves are a form of IM distortion. If two different tones are played from different sources and the frequency difference between them is XHz, where they converge in space, a composite wave will be created that includes both of the original frequencies plus a new tone equal to XHz. This has to happen in performances with multiple instruments adding to the overall character of the performance.
I don't know much about this phenomenon except that it exsist and that there is a weapon that uses it to induce low frequencies in a target person to disable them.
Rodd Yamas***a
No Bottom E? TubeHead Johnny Multi-Way 82 2nd December 2008 02:08 PM
The 'bottom end' PeteMcK Everything Else 0 18th September 2008 07:18 AM
Still lurking sandgrownun Introductions 1 6th August 2008 01:50 PM
I've been lurking too long!! matth Introductions 8 20th June 2003 01:09 AM
A new SOZ lurking.. Mad_K Pass Labs 5 14th February 2003 07:01 AM
Page generated in 0.14349 seconds (77.96% PHP - 22.04% MySQL) with 11 queries
