Old 2nd March 2005, 04:55 AM   #1
Wyloch is offline Wyloch  United States
Default Quick Question About a Crossover
Newb here. I'm building these:
http://www.wadsnet.com/~dtenney/dayton_8MTM.htm
He says to replace the 72uF with a paralleled 50uF and 22uF, but there's no 22uF in his parts list. Anyone got a recommendation of a ~72uF resistor that would work in that speaker?
Old 2nd March 2005, 05:00 AM   #2
No idea, but I think you meant to say capacitor instead of resistor.
Old 2nd March 2005, 05:10 AM   #3
Yes I did. Thank you.
Let me take this opportunity to be more specific. If you scroll down that page, there is a circuit diagram followed by some Notes. These Notes tell you which parts from the Part List (further down the page) to use in the circuit, because the parts in the part list vary slightly from the values on the circuit diagram.
Well, everything matches up and I understand where to make tradeouts except the Note that says to "Parallel the 50uf and the 22uF to make the 72uF cap." The Part List has a 50uF, but does not have a 22uF listed, unless I am a total moron.
SO, anyone have a recommendation on what 22uF cap would work in conjunction with everything else on that Part List?
Also - would this revised diagram be correct?:
[IMG]www4.ncsu.edu/~whbuchan/buchananaudio/revised.jpg[/IMG]
Thanks a ton
Old 2nd March 2005, 05:18 AM   #4
Bill Fitzpatrick's Avatar
He just forgot to list it. From the same PE page as you order the 50mfd get a couple of 22mfds.
Old 2nd March 2005, 05:31 AM   #5
Awesome. Thanks for the reply - I found it in the list. And how did my diagram look? I guess my other question is: there are two circuit diagrams, each with -V+ on them. I assume that's where you hook the input into? And since there are two circuits, do I just run two wires from each input terminal, one going to each circuit?
Also, what wire should I use to do that? Solid or stranded? Copper? What guage?
(first speaker foray here...)
Old 2nd March 2005, 06:00 AM   #6
Correct.
Copper, stranded, 18ga.(zip cord is fine)
Quick quick question ! guitvinny Pass Labs 6 7th February 2007 04:20 PM
Quick crossover question-please help me read this schematic The Paulinator Multi-Way 4 26th March 2006 10:08 AM
Quick crossover schematic question for you gurus :-) Florian Parts 2 1st November 2005 09:24 AM
Quick crossover question Urloony Multi-Way 1 11th February 2005 03:32 PM
Quick crossover questions Grahamt Multi-Way 4 10th September 2004 01:12 AM
Page generated in 0.07936 seconds (81.91% PHP - 18.09% MySQL) with 10 queries
