Old 1st March 2005, 04:09 PM   #1
Puggie is offline Puggie  United Kingdom
Default 2.5 Way for a centre speaker?
I'm looking at building a centre to go with my floorstanders (Morel units), Ideally I wanted a MTM on its side for the centre, and to have it match the stereo pair as close as possible for obvious reasons. But, my stereo pair are using 1st order Xovers and a MTM with 6dB slopes is not likely to work once you are out of the sweet spot, I would have thought 18-24dB slopes would have been needed, but this does change the voicing of the speaker somewhat. My thought was to run a 2.5way using one midbass crossed with the tweet and the other low passed to compenate for the baffle step. Now how to I go about this without causing phase problems between the two midbasses from the roll off of the bass (.5) going out of phase with the midbass.
Any thoughts on this? how should I filter the bass (.5) speaker to avoid any cancellation with the midbass. or should I consider going 3 way using one driver for the mid and crossover to the other for the bass, I can get both 4 and 8 ohm drivers so I could use the lower impedance driver to compensate for the baffle step response.
DIY Centre Speaker advice sunrise3500 Multi-Way 96 15th January 2008 11:16 AM
centre speaker garymtb Multi-Way 24 7th June 2007 11:30 AM
Stonking Centre Speaker for <£75 ?? Ovation Multi-Way 9 5th August 2004 06:11 PM
Centre speaker adaptation - anyone ? purist Multi-Way 0 29th April 2003 08:25 PM
Help with Centre Speaker andrew Multi-Way 6 2nd May 2002 07:52 AM
Page generated in 0.06910 seconds (66.48% PHP - 33.52% MySQL) with 10 queries
