I'm modeling a box right now that calls for about a 3" (7.5cm) minimum port diameter. The only problem is that this makes the port about 12" (30cm) long, which won't fit easily within the box.
Would I be better off using a bent PVC pipe of 3" diameter (without flares), or a straight 2" port that is flared? What would be the problems with a 2" port - just port noise, or something else? |
#2 |
It is always better to use a flared port to minimise chuffing (as a result of air turbulence). The other consideration is port compression at higher power levels. I suspect that these two are interrelated. Both of your proposals should work, but I'd still go for the flared port, even if it is to have a smaller diameter.
Most box calulation programs yield a minimum port diameter specification based on the assumption of a non-flared port. Flared ports often have to be a little longer (~1") to achieve the same tuning as a standard port. The tuning can be checked by doing an impedance sweep.
Shaun Onverwacht |||||||||| DON'T PANIC |||||||||| |
| Why big port diameter? | Jay | Multi-Way | 22 | 13th March 2007 11:52 AM |
| Choosing port diameter. | Jeb-D. | Multi-Way | 8 | 18th August 2006 06:34 PM |
| Port Diameter | jwatts | Subwoofers | 18 | 19th May 2006 11:22 PM |
| Minimum Port Diameter | Narcisse91 | Subwoofers | 13 | 22nd March 2006 07:31 AM |
| Port Diameter Question | BAM | Multi-Way | 3 | 14th November 2001 01:19 AM |
| Page generated in 2.76469 seconds (3.16% PHP - 96.84% MySQL) with 10 queries |
