Old 27th February 2005, 08:38 PM   #1
Default Max spl question
p=Sd*Xmax*f^2*pi*rho0/(r*sqrt(2))
i know what everything in there means, but what the heck is "sqrt(2))"
some advice?
My 100$ (final cost) line arrays will blow you away
Old 27th February 2005, 08:41 PM   #2
dooper is offline dooper  Canada
1.4142...also expressed as 2 ^ 0.5. In English, the square root of two.
dooper
Old 27th February 2005, 08:48 PM   #3
GM is offline GM  United States
GM's Avatar
The square root of 2, or 2^0.5 = ~1.4142.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 27th February 2005, 10:02 PM   #4
Default ,, got the P value, now how to convert to SPL
P value is 5.8304
formula sais:
20*log 10(5.8304/0.00002) = spl
when i type 20*log 10 in my calculator, i got 20
multiplied by (5.8304/0.00002)
is 5830400.
DOES NOT MAKE SENCE. SOMEONE HELP
Old 27th February 2005, 10:39 PM   #5
I get about 109.3 dB.
In Windows calculator - scientific view:
5.8304/0.00002 = 291520
With 291520 in the window, click log
Result is 5.4646683552929042237014952913997
Multiply that by 20 -> 109.29336710585808447402990582799
I'm sure someone will correct me if this is incorrect.
HTH,
dooper
Old 27th February 2005, 11:11 PM   #6
Does the r represent radius?
Old 28th February 2005, 12:16 AM   #7
r represents distance in meters from the microphone
Old 28th February 2005, 12:23 AM   #8
DonoMan is offline DonoMan  United States
Send a message via AIM to DonoMan
Log 10 means base 10 log. If log 10 = 1 in your calculator, then it is base 10. So just do log(5.8304/.00002). If log 10 shows something else (it doesn't show something else in your case, but for others, it may), then your log is not base 10. You can make it base 10 by doing this:
base b log of n = log(n) / log(b)
That'll work even if you're already in the correct base log.. You can get from base e to 10 or 10 to e easily that way, but you can pick any number you want.. You can do base 72.971 that way if you like.
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
Capacitor Question /question on cap TunaFish Tubes / Valves 14 12th January 2004 02:23 AM
PS question - tformer question actually breguetphile Chip Amps 2 30th May 2003 01:29 PM
old speaker question, bullet midrange question & link to speaker project wallijonn Multi-Way 10 5th November 2002 06:03 AM
Page generated in 0.17668 seconds (54.77% PHP - 45.23% MySQL) with 10 queries
