Hi!
I would like ask the experts about closed/sealed box design technics. What is the most prefered way: -Butterworth (Qtc: 0.707) -Bessel (Qtc: 0.577) -Critically damped (Qtc:0.5) What are the advantages of the closed ended TML boxes? (Like the Nautilus?) What is the "best" closed box laudspeaker on Earth? :-) Nowadays I can see most of time only vented designs. Why? Greets: Tyimo |
#2 |
Did it Himself
There is no best design, it's all a matter of individual taste.
Lower Q sealed gives better transient response and group delay/phase at the expense of larger box and earlier roll-off. Vented is popular because it gets lower cut-off and better efficiency, at the expense of transient response and group delay/phase. Box size is larger than closed, but not terribly so. Different applications (sub, only main speaker, satellite etc.) require different approaches.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
A test done on several Q points;
http://www.geocities.com/kreskovs/Box-Q.html Watch out for room gain at a Q of 1.0.... |
#4 | |
#5 |
Hi!
RJ thanks! Interesting site! Is there any rule of thumbs how to design a good closed end TML speaker? |
#6 |
I'm guessing the L in TML stands for Transmission Line. Here's a site that can explain it. http://www.t-linespeakers.org/design/classic.html |
#7 |
Hi RJ!
Thanks, I know this site already and there is nothing about closed end TML speaker design. :-( I know that the closed box geometry need to absorb the back waves, but what about the TML 1/4 frequencies? It will be stronger? Tyimo |
| Q in closed box design | Hyldal | Multi-Way | 23 | 18th July 2007 11:05 AM |
| Closed box design:Scan Speak monitor | Jonasa | Multi-Way | 74 | 13th May 2007 08:17 PM |
| Power Supply Design Strategy--Solid State for Tube Amp, From Morgan Jones | DrDeville | Power Supplies | 0 | 14th December 2006 09:18 PM |
| Lambda TD12s Closed Box / Bass Reflex Design | akunec | Multi-Way | 7 | 13th September 2005 02:44 AM |
| Closed box design using W.M. Leach | ppfred | Multi-Way | 5 | 23rd December 2004 09:37 AM |
| Page generated in 0.15497 seconds (66.42% PHP - 33.58% MySQL) with 10 queries |
