Sorry for the beginner question, but I have finally decided on a project, only I'm not sure how to finish off the cabinet. From what I read paint and MDF don't go together well. Veneer I was told without veneer press forget it. Self-sticking foil in wood/or stone motifs has been suggested to me but they just don't appeal to me. So what did all of you use?
Can you get a smooth shiny finish on top of structured paint and if so how? |
#2 |
There are experts on all types of finishes here. Paint works. Veneers work.
Just decide what finish you want, you'll get way too much advice. Did you read this thread?
onasis |
#3 | |||
Some use another piece of wood and clamps to press the veneer on your enclosure. Others use a method with a flat-iron. Quote:
Smooth... you would have to apply many layers but it should work IMO. http://www.visaton.de/vb/showthread....it+effekt+lack Granite effect lacquer. One of my favourites as it is quite easy to get good looking.
jens |
#4 |
I'm not an expert on veneering but why would you HAVE to have a veneer press to veneer speakers?? Especially when it's your first project. Veneer, contact cement, and a router should do just fine, no?
If the corners are left unrounded use the router to cut the veneer flush with the edge after you've glued it. Or if you round the corners of the speakers enough you could use one piece of veneer for all four sides by wrapping it around. If you do this you have to spray water on the part of the veneer that will bend at the corners and let it sit for a bit to loosen up (use a plastic spray can for the water). Be very slow and apply lots of pressure on the speaker when you bend around the corners. Use a long (and very straight) bar of metal or something like it (the beefier the better) or find a very flat surface and just use the speaker's own weight for bending. You'd have to experiment to find what works best for your size of speaker. Also the size of the rounded radius of the corner must be big enough to do this, at least 3/4 inch maybe?
The End |
#5 |
try leather or a leatherlike vinyl.
1. It easy to work with 2. all you need is a razor,a ruler and contact cement. 3. You can get almost any color 4. Enclosure damping(less sound radiating from enclosure) |
#6 |
i used granite paint over flat black enamel. similar to the stuff shown in the link by joensd, but black with white and grey flecks in it. looks great!
Kenwood VR6070, Panasonic 53wx53, 3 sets of double advents across the front, dual 1245, MA282e. |
#7 |
I use fur fabric.
https://mrevil.asvachin.eu/ |
#8 |
First off I read the thread on piano black paint. My concern with paint is the uneven absorbtion on the edges in comparison to the flat surfaces. Since my motivation for using paint was to simplify things the idea of sealing those edges with putty or anything else started to become discouraging. Veneer: I asked a pro and got the pro answer. I assume however that I could simply glue it and it would hold. Might not be Ideal but it's a DIY job so ideal is really not an issue. I considered Leather. But I can't quite picture a speaker of this size in leather in my living room (116cm tall). It's the WAF thing. Maybe I'm wrong, but I'm looking for ideas so if you've got 'em, i want 'em. Thanks for the input thus far. I am still leaning towards a product from elesgo called elesgoflex. It'S not my preferred solution but this is my first project and I think it would be the easiest alternative.
#9 |
Did it Himself
Basically MDF soaks up paint big time, especially the edges. In the UK e can buy a product made by International called MDF Primer. It's basically a primer paint that seals the wood, so your top coat goes on evenly. For a cheapskate version of it you can make a 50/50 mix of PVA glue and water. Apply 1 or 2 coats, with a light sanding inbetween each. Then paint over with ordinary wood primer/undercoat.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#10 |
Check out this post on the Madisound Board.
http://www.madisound.com/cgi-bin/dis...gi?read=336665 Cheers, CFB |
| Cabinet finishing. | crewsa | Multi-Way | 2 | 22nd January 2006 03:29 PM |
| Cabinet finishing | vteg | Multi-Way | 20 | 3rd January 2004 09:10 PM |
| Need advice on cabinet finishing (lacquer) | alphaGeek | Multi-Way | 23 | 25th March 2003 05:24 PM |
| Finishing MDF | Vivek | Multi-Way | 4 | 11th April 2002 04:23 PM |
| Page generated in 0.11300 seconds (87.77% PHP - 12.23% MySQL) with 11 queries |
