i had to remove the plastic veneer do to damage. now its just mdf
is wood venner anygood? and how hard is it to install? what other types are there? thanks |
#2 |
You can get paper backed self adhesive wood veneer that works well and is ease to use. Its not that expensive either.
If it sounds good... it is good! |
#3 |
Self adhesive veneer is one way to go as mark mentioned. The other way is to use standard wood veneer and apply some sort of neopren glue to it as well as to the enclosure. Let it dry for some 15 minutes and then put the veneer to the enclosure using ironing method. It works fine. Watch out for bubbles.
#4 |
thanks for the replys. i think ill go with the glue and wood idea with the iron. sounds like it would give it a more natural look of wood. ill post some pics when finished..
thanks... |
#5 |
Most of this idea is good. You really can apply veneer with contact cement. But using an iron is not something that I would reccomend to a first timer. It may help in some way but I'm hard pressed to see how.
A way that will work is to make yourself a rubbing stick. Which is shaped like a large paint brush. You round over the "brush" end so that you can apply pressure to the surface of the veneer without damaging it. Then you rubb or push as hard as you can on the surface of the veneer so that the contact cement (that is dried on both of the surfaces as per manufacturers instruction) can come into intimate contact. ( Put your sub in a dark room and wait for the baby subs ) I sugest that you try latex based contact cement on a test piece and get a feel for it before working on the sub. Better to make your mistakes on something that you can throw away Mark
Mark |
#6 |
When using paperback veneer and contact cement I've found it beneficial to coat both surfaces (veneer back and MDF) with contact cement, dry it completely with a heat gun or hair dryer, then apply a second coat and drying it completely before attaching the veneer.
| "Everything" you need to know about fancy wood/veneer | dhenryp | Multi-Way | 2 | 18th April 2005 01:11 AM |
| Veneer on veneer?? | sam9 | Multi-Way | 5 | 1st August 2003 06:21 AM |
| Veneer | Nathan | Multi-Way | 21 | 11th May 2003 05:52 PM |
| Calling Veneer Experts: Iron and Wood Glue | Milzie | Multi-Way | 20 | 26th December 2002 01:09 PM |
| Some Q's on Veneer | WhiteBoyChriss | Multi-Way | 6 | 27th November 2002 12:13 AM |
| Page generated in 0.09016 seconds (72.66% PHP - 27.34% MySQL) with 11 queries |
