Old 26th February 2005, 12:16 AM   #1
bser is offline bser  United States
Default small enclosure speaker
wondering what exactly to look for in a speaker that will perform well in as small of an enclosure as possible. I know Vas plays a role as well as Qts. But looking at thischart I can't find any corellations between Vas, Qts, and manufacture recomended box size. I'm looking specificly for drivers to put in fiberglass kickpanels in my car. What should I look for when choosing a small box driver?
Old 26th February 2005, 12:38 AM   #2
Stocker is offline Stocker  United States
You look for something that models well in the software program you use to design the box. Manufacturers are free to specify their box sizes as they wish, for whatever frequency response they think is ok that week. Don't trust their box size numbers unless you *really* want to got the easiest route possible.
Jesus loves you.
Old 26th February 2005, 12:41 AM   #3
dooper is offline dooper  Canada
Closed-box theory is fairly simple.
Qtc is defined as the system Q at fc, which is the system resonance frequency. Qtc will usually range from 0.5 to 1.2.
Vb is defined as the net internal volume of the enclosure.
a (alpha) is equal to Vas/Vb
a = (Qtc/Qts) ^ 2 - 1
Using the Dayton RS125S-8 as an example, and using Qtc = 1.0 as a target:
a = (1/0.52) ^ 2 -1 = 2.698
Therefore Vb = Vas / a = 0.12 / 2.698 = 0.0445 cu.ft.
You can see that the 0.15 cu.ft. enclosure on the chart has a Qtc equal to somewhat less than 1.0. Make sense?
dooper
Old 26th February 2005, 01:00 AM   #4
makes great sense! thanks so much for the helpful response in layman terms.
Old 26th February 2005, 02:38 AM   #5
Coil Height (Hvc) : 11.3 mm
Compliance (Cms) : 1.22 mm/N
Cone Area (Sd) : 132 cm
D.C.Coil Resistance (Re) : 3.2 ohm
Electrical Q (Qes) : 0.50
Equivalent Suspension Stiffness (Vas) : 30 Liters
Force Factor (Bl) : 4.3 T-m
Free Air Resonance (Fs) : 43 Hz
Frequency Response : 45 - 15kHz
Gap Height (Hag) : 5 mm
Impedance (Nominal) : 4 ohm
Inductance (Le) : 0.80 mH
Linear Excursion (X Max) : 3.15 mm
Mechanical Excursion (Peak-to-Peak) : 16 mm
Mechanical Q (Qms) : 4.90
Moving Mass (Mms) : 11.2 g
Sensitivity : 90dB
Total Loudspeaker Q (Qts) : 0.45
From my calculations (i'm terrible at math) a speaker such as this one would not be suitable for a small enclosure in mind.
using your formula with a goal Qtc of 1 again (not actually sure what I want this to be, inputs appreciated)
1.06/Vb=(1.0/.45)^2-1
After doing the math I get an enclosure size of 3.23 ft^3!!!! That can't be right can it? What am I missing?
Old 26th February 2005, 02:52 AM   #6
Hope this helps:
a = 3.94
Vb = 30 / 3.94 = 7.62 liters = 0.27 cu. ft.
dooper
Old 26th February 2005, 10:28 PM   #7
maybe you can resubmit the equation you used without any numbers in it so i can get an idea of where everything goes, sorry to be a pain, but math doesn't come easy to me.
Old 26th February 2005, 10:49 PM   #8
No bother
a = (1 / 0.45) ^ 2 - 1 = 2.2222 ^ 2 - 1 = 4.94 - 1 = 3.94
Vb = Vas / a
1 liter = 0.03531467 cu. ft.
7.62 liters = 7.62 * 0.03531467 = 0.27 cu. ft.
dooper
Old 27th February 2005, 05:00 AM   #9
thanks so much for your patience. Consider yourself lucky if math comes easy to you I'm not a stupid person I've just got a mental block with numbers and math
Fostex 108 Small Enclosure Ronmeister Full Range 39 23rd February 2009 01:55 AM
Small Enclosure Woofer h_andree Multi-Way 5 28th March 2008 09:25 AM
What to do - small enclosure, odd shape Lothar34 Car Audio 5 4th November 2006 01:55 PM
best spl sub small enclosure 500w scottcanny Subwoofers 1 27th August 2006 11:21 PM
Page generated in 0.08795 seconds (87.39% PHP - 12.61% MySQL) with 10 queries
