ok... i am thinking about a dipole system... a small 2 way connected with larger subs.
what frequency should I cross my subs to the dipole 2-way and how wide should I make my baffle on the 2-way? should I roll of the low frequencys more on the 2-way? Thanks!
It is not you... you are it. |
#2 |
Banned
My dream is to build a set also. but what drivers are you going to use ?
#3 |
Money, money, money - what's your budget?
The larger the baffle is, the lower and louder the bass will go (but never any louder than if it was a monopole speaker). Ideally, you'd cross at or below 80Hz, but since it's a small 2-way, you won't have enough output at that frequency, so the subs might have to go up to 100Hz-150Hz. Of course, this could change, depending on how loud you listen to music. The higher you cross, the more important sub positioning becomes. Are you constrained to a 2-way system because of space requirements? |
#5 |
i have a low powered tube amp for the small 2-way dipole.
probably run a powered sub for rest. i am just looking for what frequency i should cross a sub and my monitors over at to determine baffle width of the small 2-ways. also need to determine what drivers i want to use...
#6 |
One sub for two satellites?
#7 |
Banned
My dream drivers would be the davis ones from partsexpress.com : O ) and a nice ribbon tweeter..
J' |
#8 |
Suggest you go to SL's site and work with his dipole calculator (excel spreadsheet). That will show you driver excursion vs baffle width etc.
my dipoles |
#9 |
Banned
Where is this file and where is the Calculator ? Its not on that link you gave us..
#10 |
| Dipole Sub question | zobsky | Subwoofers | 63 | 23rd May 2008 10:50 PM |
| Dipole Sub EQ question | weinstro | Subwoofers | 1 | 15th August 2007 12:01 AM |
| Mtm Dipole Question | trusound | Multi-Way | 5 | 27th January 2006 11:51 PM |
| Dipole sub question | needtubes | Subwoofers | 1 | 15th August 2005 02:37 PM |
| dipole question | a007udio | Subwoofers | 2 | 3rd April 2005 08:29 AM |
| Page generated in 0.09901 seconds (77.37% PHP - 22.63% MySQL) with 10 queries |
