Old 25th February 2005, 09:30 PM   #1
sdclc126's Avatar
Default Connecting EQ to Surround Receiver
Hey - I know this is the loudspeaker forum but I figure anybody here can answer this (except me) - I want to get a multi-band equalizer for my system, but I just have a surround sound receiver - no pre-amp, etc. Will it work with just line in/out? I can't see how the signal gets back to the receiver from the EQ. Maybe I'm missing something. Thanks.
Soft Dome
Old 25th February 2005, 09:50 PM   #2
Glen B is offline Glen B  United States
If your receiver has a tape (monitor loop) that is independent of the input selector, you can insert the equalizer (or any other sound processing equipment) in that loop. The line input of the equalizer gets connected to REC/OUT of the tape loop and the output of the equalizer should be connected to the PLAY/IN jacks of the tape loop. When the tape monitor button is in the ON position, the EQ will be inserted in the receiver's signal chain. When the tape button is in the OFF position, the EQ is removed from the signal chain.
Old 25th February 2005, 10:06 PM   #3
sdclc126's Avatar
Default Tape In/Out Loop...
OK that makes perfect sense - I should have known but now I do - I just have to check my receiver for available connectors now. Thanks a million!
Soft Dome
Old 26th February 2005, 02:30 AM   #4
When I tried to install an EQ in my tape monitor loop it ONLY worked with an analogue signal AND being played in analogue. It did not work with the digital inputs of my DVD or CD.
Probably a silly question, but ........
Old 26th February 2005, 02:59 AM   #5
It could be that with digital signal sources your receiver bypasses the tape loop.
Old 26th February 2005, 09:46 PM   #6
sdclc126's Avatar
All my connections are analog, but my system is capable of digital, which I'm thinking of switching to - so maybe I should forego the EQ?
Soft Dome
Old 28th February 2005, 06:38 PM   #7
Bose(o) is offline Bose(o)  Canada
EQ would be applied to all channels eh. Maybe you can emulate the EQ that THX receivers apply to the signal, I'm pretty sure that it's applied to all channels as well.
ERTW 4 life!
"the day has 24hours. If that is not enough take the night."-Roemhild
Old 28th February 2005, 07:15 PM   #8
sdclc126's Avatar
Thanks - gonna get the EQ!
Soft Dome
axial surround instead of radial surround Calvin Subwoofers 22 13th July 2009 07:46 PM
Yamaha surround receiver questions daring Chip Amps 6 6th July 2008 09:28 PM
[WTB] Cheap DD/DTS 5.1 surround receiver vision Swap Meet 0 9th January 2007 09:21 PM
Connecting receiver's remote control out to computer bobo1on1 Digital Source 0 29th May 2006 03:02 PM
Surround sound from an integrated stereo receiver ? fireman Everything Else 4 20th January 2004 01:39 PM
Page generated in 0.10806 seconds (74.11% PHP - 25.89% MySQL) with 10 queries
