Old 25th February 2005, 11:04 PM   #11
I know the feeling, same thing happened to me when i built a small bandpass box, i dident use any electric tools tho, all pieces got cut all wrong two sides had to be redone in plywood. The finished result was the worst built box i ever seen, none of the sides were cut straight so there were openings about 3mm between sides. The next box i made cutting the sides with an old carpenters hand saw went as close to perfect as its possible to do with hand power, almost no planing at all was required I still havent sanded and painted it.
Old 26th February 2005, 02:08 AM   #12
Shaun is offline Shaun  South Africa
Shaun's Avatar
Default You can re-attach the cut-offs
I usually order my MDF pre-cut. Imagine my dismay when discovering I was one piece short!
No problem- I was able to glue two pieces of scrap wood edge-on to make a larger piece, then only needed to trim off one end (luckily).
So, if you're desperate, you could try re-attaching your cuts. Just remember to clamp it well.
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
Sony VFET...tragic... EchoWars Solid State 21 11th November 2006 12:40 PM
Flame On!: Tragic loss of magic smoke KBK Solid State 28 29th October 2006 06:26 PM
My Tragic story about Emission Labs tube Michaellu5250 Tubes / Valves 2 31st May 2005 02:04 PM
At a loss... cunningham Class D 21 23rd September 2004 07:29 AM
Page generated in 0.06662 seconds (74.65% PHP - 25.35% MySQL) with 10 queries
