I finshed my first speaker project last night and am pleased with the results. It's one of the Dayton Home Theater speakers. Yeah, just one. I wanted to see if I liked it doing it, and if I liked the result. Comparing it to a single Rock Solid satellite (circa 1993, designed by B&W, made in Japan) it's got a bit more air up top and and cleaner, tighter bass below. But, it's less efficient, and I was also able to bottom out the mid driver without too much volume, which was a tad disappointing. Overall, though, a good starter project, and way easy to build.
So, now a decision - to finish the set of five speakers, or to do two more Dayton HTs for the rear (using the already completed one for the center) and make two other types for the fronts, shooting for a little more musicality. It'll take about $200 to do the remaining 4 speakers, and I've got about $300 in mind for a sub. I could juggle things a bit, and swing another $100 for the mains. That would bring the AR.com set in range, which seems to have excellent reviews. But what about matching timbre, and other such concerns? If it comes down to taking a couple bucks from the woofer project, should I? Is the problem that I'm trying to use the same system for both music and HT? Or should I just get the first matched system under my belt and let myself fall gently into the abyss of upgraditis? |
#2 |
Like the rest of us, I think you'll upgrade.
Personally, I do watch 3 movies/week. But, I could careless for voice matching through all 5-7 channels. The 2 main fronts and center has more voice than the rest. I would build the better front channels first. |
| 1st build done. | bloozestringer | Tubes / Valves | 8 | 14th January 2009 01:22 AM |
| What to build with +/-65V? | Lovan | Solid State | 1 | 26th February 2007 04:26 PM |
| build my first full ranger,let's build another one:a small fullrange high end pc-spea | then_dude | Full Range | 2 | 30th November 2005 07:54 AM |
| Do i need to build main supply (240v) filter?Or build power distribution? | thomgun_lc | Chip Amps | 9 | 16th September 2005 09:52 AM |
| Musicality of speakers, amps, and instruments | MBK | Multi-Way | 16 | 31st May 2004 04:04 PM |
| Page generated in 0.07647 seconds (71.80% PHP - 28.20% MySQL) with 10 queries |
