Old 22nd February 2005, 06:37 PM   #1
tmblack is offline tmblack  United Kingdom
Default marble enclosures?
Anyone like Susan Parker's marble sphere speakers?
How much does markble cost and where can one buy it?
Tom
Old 22nd February 2005, 07:27 PM   #2
hermanv is offline hermanv  United States
In my system I had a vibration feedback problem. Marble shelf didn't help sounded just like glass. Hardwood helped, isolators helped. Isolators on Marble didn't work either.
It would seem that a speaker housing should be non resonant or accoustically dead, not just heavy. The Marble I had (a slab) would ring if struck by an object. Sandstone - now that might be OK
Old 22nd February 2005, 07:49 PM   #3
How about thick aluminum or concrete enclosures?
Is wood still the best for DIY?
Tom
Old 22nd February 2005, 08:42 PM   #4
Wood is cheaper than aluminum (I think) and much lighter than concrete. You can build an inert enclosure with wood, and that's all that really matters, right?
Old 22nd February 2005, 08:43 PM   #5
Jim85IROC's Avatar
Send a message via AIM to Jim85IROC
Aluminum seems to work just fine in the Krell LAT speakers. Of course, whether or not there's an audible difference between the aluminum and some well braced MDF is another issue entirely.
Old 22nd February 2005, 10:54 PM   #6
RHosch is offline RHosch  United States
Aluminum is stiffer than wood, but has less internal damping.
Many ways to skin the cat... I prefer the easiest and cheapest method that produces a "good" skinned cat.
Old 22nd February 2005, 11:17 PM   #7
botrytis's Avatar
Send a message via ICQ to botrytis
There was a little speaker manufacturer from britian who lined his wooden speakers cabinets with either lead or steel. Doing that really made them inert!!
Dave
Old 23rd February 2005, 01:29 AM   #8
justinc is offline justinc  United States
what about taking 2 1/2 inch pieces of mdf and spreading a thin 1/4 layer of concrete between them to connect them? seems it woudl be pretty rigid.
Old 23rd February 2005, 02:14 AM   #9
kilowattski's Avatar
That wouldn't work either. The MDF would wick the water out of the concrete. The wet MDF would fall apart and the concrete would become brittle.
Kilowattski
Old 23rd February 2005, 02:57 AM   #10
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
some speaker companies do sandwich an elastomer adhesive between two layers of MDF
Marble/Granit Tile HT Sub spudfrog Subwoofers 6 15th June 2007 07:17 PM
satellites for marble sub Artmaster Multi-Way 0 15th November 2004 12:17 PM
working with marble karma Everything Else 6 8th September 2004 10:54 AM
marble subwoofer Artmaster Swap Meet 2 1st July 2004 04:15 PM
marble?!! 91TB78 Everything Else 8 13th November 2002 04:39 PM
Page generated in 0.09116 seconds (77.23% PHP - 22.77% MySQL) with 10 queries
