Could use your help for school club project
Old 21st February 2005, 09:56 PM   #1
JZatopa is offline JZatopa  United States
Default Could use your help for school club project
I recent joined a club at school that is a group of DJ's. The problem is that the club needs some monitors (just one would do). They use computer speakers and it just isn't working so they would like to buy something. Before I joined they were looking at getting a pair of powered speakers and a sub for $250. I told them that they should get a single quality monitor and go from there. I have built speakers before and I suggested that we build speakers so we could get something that would work better then what we could afford. I could use advice on what you guys think would be a good way of doing this. Here are the criteria that need to be met. It must be portable, loud, powered (if possible) and have clean loud bass. These speakers don't have to be very detailed or even look that good. I was thinking that a pair of tweets from apexjr (they are $15 a pair) and a good 6.5" or 8" driver would be best. I would prefer sealed due to the added power handleing because I seem to be one of the few DJs who know when a speaker is distorting. Any and all advice and or cheap parts you guys can contribute would be great. If you feel we would be better off buying something please let me know.
Knowledge is Power & Applied Knowledge is Freedom,
There is no higher religion than truth
Old 22nd February 2005, 10:49 PM   #2
noone has any advice?
Old 22nd February 2005, 11:17 PM   #3
Bill Fitzpatrick is offline Bill Fitzpatrick  United States
Bill Fitzpatrick's Avatar
These might fit the bill:
http://www.wadsnet.com/~dtenney/dayton_8MTM.htm
Old 22nd February 2005, 11:50 PM   #4
BHD is offline BHD  United States
BHD's Avatar
Send a message via Yahoo to BHD
http://www.pispeakers.com/
Check out the kits - the prices are per speaker. Super efficient, and you'd have to play them really loud to get serious distortion. I think the theater four would be just the ticket...
My religion is the golden rule. The only time it's forsaken me is when I've forsaken it first.
Old 23rd February 2005, 12:43 AM   #5
The pi speakers may be the ticket. For a retail product I was looking at the carvin active studio monitors. What do you guys feel about those?
Old 23rd February 2005, 12:53 AM   #6
BHD's Avatar
I haven't heard the Carvin active monitors, but I have heard their guitars and amps. They build good stuff and since it's factory direct their products are usually priced right. My buddy's bass is a thing of beauty and sounds great, too.
On the other hand, no matter what you build, why not build your own? You'll likely stretch your dollar further and get some valuable experience. Sounds like the epitome of a school project, as far as I'm concerned.
Old 23rd February 2005, 12:55 AM   #7
Well the carvin's arn't DIY. They are just a pair of powered monitors. I am worried that if we were to build a pair of pi speakers the amp that would be needed to make them active would put us over budget.
Old 23rd February 2005, 01:08 AM   #8
BHD's Avatar
At 98 db for the Pi fours, I doubt it. You wouldn't need much power.
98 db 1 watt
101 db 2 watts
104 db 4 watts
You get the idea. Unless you're in a gymnasium, you won't need a lot of power. A gainclone or really cheap chip amp would play freakin' loud.
Good luck.
Old 23rd February 2005, 01:29 AM   #9
warren o is offline warren o  United States
These are DJs?
Get them some serious reinforcement speakers; either build ‘em or buy ‘em.
Take a peak:
http://www.partsexpress.com/webpage....&WebPage_ID=27
http://www.renkus-heinz.com/
http://www.eaw.com/
http://jbl.com/
http://www.sweetwater.com/shop/live-sound/pa-speakers/
http://www.zzounds.com/cat--Live-Sound-PA--2713
Standard audio system speakers are designed for a different application & will not hold up being carted around and pushed hard. There are speakers designed for this task. The best are EAWs & Renkus-Heinz. They are very pricey, though.
I recommend buying the parts & having the kids help build them. It will give them ownership (so maybe the will be kinder to them) and be a learning experience, too.
Good luck.
Old 23rd February 2005, 04:58 AM   #10
I understand the pi speakers are very effecient but the amp needs to be attached to the speaker. These also need to be easily carried. If I had the means I would bring me ev eliminators and an amp but that is just to much of a hassle. Warren I will look into those options.
If someone knows of a cheap full range amp that could be attached to the pi speakers ($50 or less) that would help out a lot.
Could use your help for school club projectHide this!Advertise here!
School Project ideas anyone? edjosh23 The Lounge 6 8th March 2005 04:54 PM
School Project batkey Chip Amps 8 14th September 2004 02:09 PM
Need help with school project neonmoose Solid State 9 15th June 2004 08:44 PM
School Project Number04 Solid State 10 27th October 2003 04:00 PM
DAC for my cd-pro II school project BrianGT Digital Source 0 8th September 2003 01:45 AM
