Im trying to model a 40hz folded horn for the Dayton 295-310. I cant seem to figure it out right. My responce rolls off very sharply at 80hz. Can someone model this for me? Im doing a T/L for this driver also, and i want to compare. Thank you!
http://www.partsexpress.com/pdf/295-310z.txt There are the Clio T/s Parameters. Thanks guys!
#2 |
Post your horn design (a screen shot of the hornresp input screen would work well), and then maybe people can point out why it's not working.
#3 |
can anyone model this for me? TIA guys.
#4 |
Mmmm, the T/S parameters in that text file don't match what is displayed on the PE site for that driver. Due to D=162mm in the text file, I would say it is the wrong info. Something that is not specified in either location is Sd, which Hornresp requires.
Find the correct complete specs, and modelling will be much easier. Cheers Graeme |
#5 | |
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#6 |
Ahh, therefore D= cone diameter ? .... not really a standard T/S parameter.
However, using GM's Sd calculation, a quick rip up gives the following result - assuming corner loading, and could be tweaked further (but a starting point) Cheers Graeme |
#7 |
Apparently, at least it works for the listed BL/Mms/Cms specs. I'm not familiar with CLIO so just assumed it was one of its programmer's idiosyncrasies.
GM
#8 |
How many whats is that modeled with? thanks.....
| Baffle Step & Freq. Resp. Combiner Help | 69stingray | Multi-Way | 0 | 24th May 2007 03:14 PM |
| Flat resp not best for subsonic? | mashaffer | Subwoofers | 12 | 1st August 2006 07:48 PM |
| 110 hz freq resp dip | MichaelJHuman | Subwoofers | 5 | 16th September 2005 09:28 PM |
| ATC Dome Mid Freq Resp -click here- | amo | Multi-Way | 0 | 15th July 2003 12:43 AM |
| Dynaudio 17W75 freq resp compensation | ergo | Multi-Way | 1 | 5th July 2002 08:53 PM |
| Page generated in 0.07753 seconds (83.53% PHP - 16.47% MySQL) with 11 queries |
