#11 |
If you are particularly interested in experimenting with beryllium drivers, don't forget GOTO from Japan.
regards Walter |
#12 | |
2. The sensitivity is rated at 93 Db/W/m, which is good. The magnet shouldn't be much of an issue here. 3. See above. 93dB/W/m is not 'such a low efficiency'. And the 'high' fs is probably due to the light weight of the dome. If anything, I would rather they increase the mass a little to lower the fs with an associated lowering of efficiency, but that certainly isn't for me to decide 4. Why? Or maybe I should ask, what do you mean? I don't see a problem using this driver crossed over at 2.5kHz, which would be a good two-way. 5. Good off axis response is normally a good thing. Based on your assumption, just about any tweeter would need to be a three way (at least), so I don't really think that is related to the this tweet. Very nice looking, exceptionally small faceplate - and the faceplate is thicker than the magnet! Now, kevinlomax, where can you get this tweeter anyway? And the price? (Or is it one of those cases where if you have to ask, you can't afford it!) |
#13 |
Magnets are VERY important to sound quality.
93db isn't very good for such a low mass diaphram, if anything it should be considerably better than a titanium version. near fs the driver becomes increasingly distorted (i.e. your CSD will look like crap), ultimatly this means you will need a very steep crossover to get anywhere near the driver's fs while maintaining quality output. Additionally, to maintain good dispersion you will likely need a mid driver with a fairly small diameter. This isn't to say though that you couldn't use a driver with a larger diameter and less off-axis output (in the crossover region), but the freq. balance will suffer as a result (though this could be advantageous - i.e. the BBC "dip"). (note: I was just assesing the driver from the specs provided..)
perspective is everything |
| The Whole Truth About Beryllium Diaphragms | mowry | Multi-Way | 280 | 25th June 2009 07:50 AM |
| beryllium ScanSpeak and other new goodies | stuman | Multi-Way | 8 | 24th April 2009 10:57 PM |
| Yamaha Ns Beryllium Mid And Tweeter | jeffshort2000 | Swap Meet | 11 | 5th December 2007 05:20 PM |
| Beryllium drivers on the cheap?? | NV&H | Multi-Way | 7 | 19th August 2007 01:09 AM |
| Page generated in 0.08108 seconds (73.26% PHP - 26.74% MySQL) with 11 queries |
