Old 17th February 2005, 03:37 PM   #1
flaevor is offline flaevor  United States
flaevor's Avatar
Default help with round enclosures
I really want to build some round enlosures and I have read that some of you have or are planning on it. I fond some round styrofoam balls at a craft store that are hollow and can be separated into two halves. The have them in 20cm, 25cm, 30cm and I think two size above that. I figured I could just encase the styrofoam with fiberglass. The question I have is should I use resin and fabric or just use fiberglass filler or filler and fabric or, or...I have never worked with this stuff. Tto me the resin and fabric approach seems to be more work but for whatever reason I suspect that it would be stronger. I'd appreciate any feedback unless it is to denounce rond enclosures ; ).
BTW my first post...
Old 17th February 2005, 03:46 PM   #2
tiroth is offline tiroth  United States
Great idea for a frame.
Remember, spherical inner chamber is quite possibly the worst possible enclosure shape...you may wish to build some kind of box inside the sphere. (spherical outer shape is great though)
Old 17th February 2005, 05:12 PM   #3
gary f is offline gary f  Canada
gary f's Avatar
I don't about spherical enclosures. I did a small two-way with curved pannels. I used many layers of thin wood, with epoxy glue and lead layer in between. The result is great, both in apparence, rigidity and damping. I highly suggest this, but this is quite long to do
Old 17th February 2005, 05:14 PM   #4
gary f's Avatar
Other image
Is that the kind of things you had in mind? Maybe it's not round enough.
F
Old 17th February 2005, 05:25 PM   #5
scone is offline scone  United States
I was under the impression that a spherical inner chamber is the most ideal enclosure design. I thought people didn't build them that way simply because it's very hard to implement.
audio projects
Old 17th February 2005, 05:42 PM   #6
flaevor's Avatar
My aim is something sphereical and the real heart of the question is purely structural, should i work with resin and some fabric or use filler or use both.
I like your design and had though about doing something similar but it would be a lot of work for a lot of tools I don't have.
Old 17th February 2005, 06:07 PM   #7
A spherical chamber will have only one main resonance, but much more intense than the three main resonances in a rectangular box.
One could possibly make a helmholtz resonator tuned to the resonant frequency inside the spherical chamber, and place it where the resonace is at the most intense (in the center of the sphere) A tube placed from top to bottom inside the sphere with tuned holes in it should probably do the job, or a smaller sphere suspended inside... Well just an idea...
Peter
Old 17th February 2005, 06:12 PM   #8
Yes, I think that option has been discussed as possible. I don't know that anyone has ever tried.
MarkMck did some great work where he demonstrated using real enclosures that rectangular prism was superior to egg/sphere shape. Think about it: if a cube is bad (three pairs of parallel sides with identical dimensions), how much worse is a sphere with an infinite number of parallel identical dimensions?
Old 17th February 2005, 06:23 PM   #9
Some resins will melt or dissolve the styrofoam while curing, test the resin and let it fully cure before you cover the whole sphere.
Fiber glass and epoxy resin should work fine.
Peter
Old 17th February 2005, 07:02 PM   #10
Yes, i totally agree with you, an infinite number of paralell dimensions would make an extremely strong resonance. But if we were able to kill that resonance, there would not be any other to worry about... Well, the multples of the main resonance could possibly make some trouble...
Check out these round enclosures studiotech Multi-Way 18 13th March 2006 04:03 PM
Round ESL just.sounds Planars & Exotics 9 5th January 2006 01:08 PM
WA Design Round Up ShinOBIWAN Multi-Way 1 1st October 2005 10:04 PM
Who is the person with round speakers/enclosures on avatar? sqlkev Multi-Way 10 25th January 2005 11:52 PM
Page generated in 0.10329 seconds (79.82% PHP - 20.18% MySQL) with 11 queries
