Old 16th February 2005, 10:57 PM   #1
pinkmouse's Avatar
Default So does a MLTQWT actually sound like a TL?
Well, thanks to the kindness of another member here, Jamie F, I have aqquired a pair of classic drivers, Kef B139 SP1044s, in return for a few bottles of ale!
I have run them both through Speaker Workshop to check parameters, and they all match up to the published stats pretty well. I spent the best part of a day running them through MJK's worksheets, and came up with a pretty good design, a single fold box with a line length of 120", tapering from 1.5 Sd down to 0.5 Sd. Conventional, but with a few woodworking twists I might build in.
However, I then had a quick play with the MLTQWT worksheet, and came up with some interesting other possibilities. Normally, I would just build test boxes of both types and compare, but lack of time and funds are prevailing currently.
So, to the $64000 question. I love TL bass, to me it is the only real way to do bottom end, (perhaps dipole is close, but I don't want to get into that at the moment). I have owned and built BRs and sealed, but no matter how optimised, never been totally happy with the results. So, does the ML port on the MLTQWT sound as good as true TL, or do you get those port artifacts typical of BR boxes? Opinions please from those that know what I mean, I don't want this to devolve into a meanless debate about box type, just relevant comment from those that have built and listened to both and can offer valid comparisons.
cheers
al
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 17th February 2005, 08:12 AM   #2
frugal-phile(tm)
planet10's Avatar
Default Re: So does a MLTQWT actually sound like a TL?
An ML-TQWT -- ie an expanding TL with a restricted terminus and the driver offset so as to kill off the 1st undesirable resonance uses geometry tricks to get as much low pass functionality before damping as possible... small amount of damping means more bass reinforcement. Left with low damping, you will have the double saddle of a BR, similar group delay, but the big advantage of using th e qaurter-wave resonance to your advantage.
A traditional TL with the driver at the end will need more damping -- add enuff damping and it becomes aperiodic and one of the impedance bumps decreases and you start getting group delay closer to sealed, but less reinforcement of the bottom. Of course you can damp the ML-pipe to be more aperiodic as well.
Did you try anything with steeper taper, shorter, and an offset driver?
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th February 2005, 08:47 AM   #3
pinkmouse's Avatar
Default Re: Re: So does a MLTQWT actually sound like a TL?
I suspect I may be too traditional in my approach to what a TL should be to get the best benefit from Martin's wonderful worksheets. I really must try harder to throw away my preconceptions.
The problem with the ML design is as I suspected, the group delay and double impedance peak really will have the negative BR type results I am trying so hard to get away from, so whilst it may suit some, it's not what I want.
Time for me to re-read Martin's paper again and start thinking out of the box...
Al
Old 17th February 2005, 09:02 AM   #4
frugal-phile(tm)
planet10's Avatar
Default Re: Re: Re: So does a MLTQWT actually sound like a TL?
Originally posted by pinkmouse
re-read Martin's paper again and start thinking out of the box...:
Download the tables... plug the B139 into it and grab the 10:1 line as a starting point...
dave
Old 17th February 2005, 09:11 AM   #5
Puggie is offline Puggie  United Kingdom
We have a set of those Kefs in some old Lentek monitors at work, they are a TL design, damn long 3 fold design, matched with the Kef midrange from the Rogers LS3/5 and T 27 tweet.
Old 17th February 2005, 09:12 AM   #6
Bricolo is offline Bricolo  France
Bricolo's Avatar
Hi Al,
Have you tried a ML-TL?
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease
Old 17th February 2005, 09:31 AM   #7
pinkmouse's Avatar
Gosh, Lentek, now there's a name from the past! That driver line up is very common in '70s vintage systems, much as the LS3/5 variants became a common feature in most manufacturers catalogues. Personally, I never liked the B110 as a mid much, great for plum voiced 1950s BBC announcers, but no use for music.
Al
Old 17th February 2005, 09:51 AM   #8
pinkmouse's Avatar
Hi Briccolo
I must admit, no. If you have never heard real TL bass it's hard to describe what my point is, but the definition and ambience just put ported designs in the shade. Therefore, my first post. I feared that any kind of ML would affect response, but hoped that it might not be the case, and there was a possibility of TL Nirvana in a small box. Still, seems not to be...
Time to crack on with Dave's suggestions.
Al
Old 17th February 2005, 12:35 PM   #9
We have all sorts of old BBC crap knocking about, loads of LS3/5s, 5/8s and 5/9s, Spendors, Genelec 1032s (5.1 setup with sub, very very lame IMHO, not a nice setup) and even some nice speakers (ATC SCM20A, 100A, and 100ASLs in a 5.1 setup).
I'm not a fan of the B110 either, might have some Kef T27s knocking about though if you fancy a completely KEF based project.
Old 17th February 2005, 06:04 PM   #10
frugal-phile(tm)
planet10's Avatar
In the early 80s i built up a pr of MTM B110 isobariks that i quite liked... way better drivers today thou.
dave
SE sound vs Ultra Linear sound flysig Tubes / Valves 1 9th May 2009 10:21 PM
Eighteen Sound (18 Sound) NSD 1095N Compression Drivers and XT1086 Horns opc Swap Meet 6 1st May 2009 03:48 AM
Roland VS-1 Sound Module - No Sound! jazzbee Instruments and Amps 1 3rd March 2006 08:39 PM
Martin King`s Fe167e MLTQWT hacknet Full Range 0 18th May 2004 12:43 PM
attemptint to model 4 Stryke SA071s with Martins MLTQWT sheets anannra Multi-Way 5 9th April 2003 05:33 PM
Page generated in 0.12452 seconds (80.46% PHP - 19.54% MySQL) with 11 queries
