Account Disabled
I'm about to veneer a new 24L cabinet with an American timber veneer called Rock Maple. It is the figured type, crown cut.
Has anyone had experience with this veneer? Warnings/comments/suggestions are all most welcome. :-) I'll be giving the iron-on/dry PVA method another go. My first speaker used raw unbacked veneer, but this time I chose to try out paper backed veneer. Construction pictures will be on my website... the cabinet will be used for Troels Gravesen's TJL |
#2 |
When glueing, it does have a tendency to ripple. If you can get one, (or make one), a vacuum press would be very useful.
edit: Oops, I just re-read your post and saw you're going with iron-on. So ignore my above comments. Just try not to get any water/glue on the veneer, and do a test piece first.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#3 |
Account Disabled
Hi pinkmouse,
Thank you very much for your reply. Does this mean that it tends to ripple when glueing via some regular method eg. using contact cement? I have read reports of bleed-through issues when using thin paper backed veneer with regular contact cement. Water based contact cement is a bit better. However I plan to use Pete Mazz's veneering guide. My veneer is not the pre-glued or iron-on type. It's just the regular paper-backed variety. |
| Rock - Progressive Rock ->>> | Rixsta | Music | 76 | 29th December 2011 11:03 PM |
| New speakers with American Rock Maple veneer- oil, wax or wipe-on poly? | tktran | Multi-Way | 7 | 20th July 2005 12:57 PM |
| Appleply or Maple Plywood? | bwbass | Multi-Way | 4 | 21st January 2005 03:22 AM |
| kinda off topic but i figured i would ask ya'll | kaukasion | Solid State | 10 | 22nd January 2004 04:31 PM |
| Page generated in 0.07785 seconds (73.69% PHP - 26.31% MySQL) with 10 queries |
