Perhaps an already well discussed topic, but my search did not reveal anything :
Take an example of a 2-way speaker with a passive crossover (e.g. B&W Silver Signature) and bi-wiring, where is the best place to put the crossover network ? 1) Inside the speaker -- common solution, user friendly, but get all acoustic excitation of the box. 2) Outside but close to the speaker -- improve on (1) in terms of vibration, but cables still carry signal with full frequency spectrum. 3) Remote crossover, close to power amp, long cables (one pair for each chassis) after crossover (inductance ??? ). Looking forward to some enlightening advices, Patrick |
#2 |
Hi
I would recommend placing the crossover near the amp. The benefit would probably be that the amp doesn't "see" the capacitance of the woofer cable since it's isolated through the crossover... I've done that with good results before... |
#3 |
I believe anything is better than placing the crossover inside the box. However It does require some considderation if your doing it to a pre-fabricated speaker. Mening I would use the same type of cables from the crossover to the speaker - as you may change the sound in a direction by using a different speaker cable. Also you need to considder if you want to use speaker post or just wires running out from the speaker, as you will be adding another connection otherwise. Finally you also need to considder the enclosure of the crossover. Stay away from metal if possible, as the induction fields can create unwanted distortion in a metal cabinett (unless you use MU metal)
#4 | |
Putting the crossover in a separate enclosure makes sense in a number of ways, not the least its accessibility for tweeking/changing the design after the fact. Biwiring may change the sound, but not always for the better. Its true purpose is to sell you twice as much wire. As PT Barnum said, there's one born every minute.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#5 |
Here's a method you might want to look at. The crossover is mounted vertically on the back of the speaker box, but inset so you can seal the back with another piece of wood to make everything look nice. I just came across the page yesterday.
http://member.newsguy.com/~stigerik/html/gnurk.htm . The pic is near the bottom of the page. In regards to the cable carrying the full freq. spectrum... is there any reason this is a problem? I would seriously doubt the capacitance of any decent audio cable would have an audible effect on the sound of the speaker.
audio projects |
| Passive crossover into active crossover | hahfran | Multi-Way | 16 | 10th February 2008 06:16 PM |
| Crossover location | skooter | Car Audio | 5 | 3rd January 2008 06:40 PM |
| crossover location | icanryme2002 | Multi-Way | 10 | 27th July 2007 02:28 AM |
| Passive Crossover for Passive Subwoofer? | Toast_Master | Subwoofers | 23 | 30th April 2006 12:14 AM |
| reason for crossover mounting location | jaygeorge1979 | Multi-Way | 3 | 6th February 2006 01:02 PM |
| Page generated in 0.09298 seconds (74.80% PHP - 25.20% MySQL) with 10 queries |
