Banned
many says that its a bad tweeter first of all i dont understand why its called so...... just make me clear so that i can go to buy those in 7 numbers....
I m very serious about this doubt... why it will not sound good... I want to use those in my 7.1 setup with Rotel amps.... just make it clear that why they sound bad??? |
#2 |
Almost 50 views and still no problems reported.
I say: if you like them and you think you can use them, buy them. Or try one and listen. /Hugo |
#3 |
First of all, there are probably better things out there.
Second, there are definitely much better price/performance tweeters out there that are still in the extreme high end. -Paul |
#4 |
Banned
but i want the best one no matter what is the price....
#5 |
Many people have different opinions.. It's also about how you filter it etc etc. Some say it sounds like an electrostat.. other say different. A tweeter no matter what price? Accuton maybe.. only 2699,- euro per piece D-20/6 http://www.accuton.com/e_index_netscape1152.html Thiel Greetings Remco Blankesteijn |
#6 | |
- high efficiency? - high SPL? - lowest distortion at low frequecies? - lowest distortion at high frequencies? - flattest frequency response on axis at (specify the frequency range)? - flattest response off axis at (specify angle and frequency range)? - best power response of the tweeter? - best power response of the combined tweeter and midrange? - etc, etc, etc. No one tweeter is the "best" for every application. They all, including the Scan, have strengths and weaknesses. |
#7 |
damn expensive..
im curiouse as to how much better it is than the Vifa XT25.. anyone whos heard them and can give me some pointers? they are both under evaluation for my summer project. |
#8 |
For home cinema I would believe the Stage Accompany ribbon would be the best at any price.
The ring radiators has this strange sound. It reminds me of a Heil-tweeter. It sounds like something in the lower tweeter-range is absent. It also has a significantly narrower dispersion than many usual domes. That will pobably cause some problems in a cinema. At least if you plan to have more than one person as audience.
Live sounds better than HiFi. |
#9 | |
/Peter |
#10 |
I had the same thought.
| WTS: Scan Speak AirCirc D3004/6600 scanspeak | Syonyde | Swap Meet | 1 | 17th February 2010 07:35 PM |
| Scan Speak voice coil problem? | dallaire | Multi-Way | 1 | 23rd October 2008 02:04 PM |
| Scan Speak 23W sub | Pan | Subwoofers | 15 | 26th December 2007 06:13 PM |
| A problem (or not) with Scan-Speak 9500, please help | Misa A. | Multi-Way | 7 | 10th January 2004 03:30 PM |
| scan-speak 9300 problem | macgyver | Multi-Way | 1 | 14th November 2003 01:22 PM |
| Page generated in 0.11580 seconds (79.90% PHP - 20.10% MySQL) with 10 queries |
