Old 11th February 2005, 03:20 PM   #1
Urloony is offline Urloony  United States
Default Quick crossover question
I have a two way system and am in the process of replacing the woofer drivers in the cabinet. The woofers are 6 ohm and so is the crossover. Is there any danger in using 8 ohm replacements with the same crossover? Is there another reason I should use a different crossover?
Old 11th February 2005, 03:32 PM   #2
Default NO
crossover is designed with a certain impedance in mind, to give a certain cutoff frequency. Changing to a different impedance woofer will alter the cuttoff frequency.. If you change the woofer, you have to consider modifying the crossover.
Theoretically, the enclosure is designed to suit the particular woofer based on its T/S parameters, so its not ideal to change to a different woofer.
Quick quick question ! guitvinny Pass Labs 6 7th February 2007 04:20 PM
Quick crossover question-please help me read this schematic The Paulinator Multi-Way 4 26th March 2006 10:08 AM
Quick crossover schematic question for you gurus :-) Florian Parts 2 1st November 2005 09:24 AM
Quick Question About a Crossover Wyloch Multi-Way 5 2nd March 2005 06:00 AM
Quick crossover questions Grahamt Multi-Way 4 10th September 2004 01:12 AM
Page generated in 0.07504 seconds (68.68% PHP - 31.32% MySQL) with 10 queries
