Old 11th February 2005, 04:13 AM   #1
Send a message via MSN to fishball79
Default Coated vs uncoated Scanspeak 15W8530?
Hi all,
I have a pair of older 15W8530K00 woofers which are coated. I believe the newer ones come uncoated.
Would anyone know the difference this will make? Would they simply sound slightly different or have vastly difference specs?
Chris
C h r i s
Old 16th September 2006, 01:58 PM   #2
The coated cone option seems to reduce the amplitude of cone break-up in the midrange and the associated resonant behavior .
I asked about the sliced cone Scan-speak drivers several months ago in this forum and received several helpful reply posts .
regards , Alan .
Alan
Old 17th September 2006, 03:43 AM   #3
Thanks for that Alan!
C h r i s
Old 17th September 2006, 12:37 PM   #4
Have a look at John Krutke's website - Zaphaudio - for a comparison in the 5.5" shootout
Old 18th September 2006, 03:31 AM   #5
What model number shows if they are coated? Madisound's descriptions aren't really clear on the matter...
Old 18th September 2006, 04:10 AM   #6
Mingo is offline Mingo  Denmark
15W8530 coated
15W8531 uncoated
Old 19th September 2006, 02:02 PM   #7
Default and 18W8531G ?
I've had a look at ZaphAudio and see the differences in the various plots for the coated and uncoated versions of the 15W models .
I see John K. now also has the Scan 18W8531G tested , though he does not state whether coated or uncoated cone .
From his test results' plots I'll hazard a guess it is coated , but on Tymphany's ScanSpeak data page the photo shows uncoated for this model , and no mention of coating in their text for this model nor any of the 15W sliced cone models. And to add to the ambiguity , the ScanSpeak photos show coated for both the 15W8530 models and both the 15W8531 models .
Has anyone seen a current or recent production sample of the 18W8531G00 , and can please reply here if it has a coated or uncoated cone ?
Thankyou ,
Alan
Old 19th September 2006, 02:04 PM   #8
The 18w8531g00's that I have are uncoated (6 pcs. - 4 in my Xavian XN360's - and 2 spare drivers.)
Old 19th September 2006, 02:25 PM   #9
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
18W8531G00 here is uncoated.
I thought the ones with "K" instead of the "G" were coated.
Old 19th September 2006, 02:49 PM   #10
Thanks for your replies fellows - much appreciated !
Rabbitz , have you had any success with an 18W8531G00 with a first order cross-over slope ? , and if so was its nominal crossover frequency above or below 2kHz ?
Thankyou ,
Alan
Coating coated paper cone Vivek Multi-Way 5 7th September 2008 08:01 PM
Polish / buff phenolic coated plywood? OzMikeH Full Range 7 11th May 2008 08:04 AM
Anybody can share a network for ss 15w8530 + Vifa XT25 ? 100db Multi-Way 4 16th December 2005 12:24 PM
Page generated in 0.09521 seconds (82.15% PHP - 17.85% MySQL) with 11 queries
