#21 |
Wise and well chosen words.
#22 |
alan.... a sneak peak.
#23 | |
Partly I think the audibility of the polarity difference depends on how much signal processing was done to the original program material the listener prefers , and particually if done with any of :- medium or slow attack time Compressors or Limiters ; large amounts of frequency selective equalization ; time/phase altering effects' devices . Also , whilst flat response at the centre frequency , there will be some ripple both above and below in the nearby bands owing to the specific distance between the centres no longer being very close to a half-wavelength . The amplitude of this ripple will depend on the slope of the filters used for the cross-over . rabbitz , thanks again for the photo - that is the one I saw in the other thread we conversed in -{"2-way with 8531G Revelator"}- and was refering to here-above . I would like to try a curved baffle - sides at least - to reduce the diffraction effects' result of crossing the tweeter over fairly low as it will radiate 180 degrees there . I'd like to curve the edges of the top also , but to do both with large radius will be difficult - I'm still thinking about it . This thread got a long way down the list in only 4 days ! - there is a lot of activity in this forum recently , and its good to see such !!
Alan |
#24 |
diyAudio Chief Moderator
Offcourse you are right about wideband effects, I did not expand the case since we were focusing in the transition band, plus there things are very audible vs lower and higher especially in a two way design. Cheers.
| Coating coated paper cone | Vivek | Multi-Way | 5 | 7th September 2008 08:01 PM |
| Polish / buff phenolic coated plywood? | OzMikeH | Full Range | 7 | 11th May 2008 08:04 AM |
| Anybody can share a network for ss 15w8530 + Vifa XT25 ? | 100db | Multi-Way | 4 | 16th December 2005 12:24 PM |
| Page generated in 0.09629 seconds (62.59% PHP - 37.41% MySQL) with 11 queries |
