Old 10th February 2005, 07:14 PM   #1
Vedo is offline Vedo  Croatia
Default Monacor
I need a project based on Monacor drivers(tweeter+woofer),project must be a 2-way standmounter.Very interesting drivers for me are: sph-175,sph-170al,sph-170,sph-165,sph-165kep for woofers and DT-400,dt-109,dt-25t,DT-25N for tweeters.
Thank you very much in advance!
Vedran
Old 10th February 2005, 09:23 PM   #2
There was a TL-concept with the dt-25ti and the sph-170 in one of the german hobby magazines. They said it was one of the highlights of their "cheap-trick" series.
You can see a picture of the box here http://www.visaton-bausaetze.de/hifi...ifi/vergl3.htm at the top click on "cheap tricks".
Then click on CT 202 wich is the box I'm talking about.
Old 10th February 2005, 09:31 PM   #3
Although this is a TL-box you can easily convert it to a small closed box (approx. 17 ltr.) wich will still have good bassresponse.
As long as you keep the width of the baffle the same you can use the xover that is used in the CT202. The xover parts are mentioned on the site, it's a very simple 12db/oct xover with a attenuator circuit for the tweeter.
I have a frequency response of that box, it has perfect linearity!
What about Monacor? mr_push_pull Multi-Way 8 17th October 2010 10:41 PM
BIB or TL with Monacor SPH-170 and DT-254? jaste Full Range 0 30th October 2008 01:36 PM
Monacor sph-135/AD Tomac Multi-Way 22 30th August 2006 04:30 PM
Monacor MSH-115 (116) Michail Bugaria Multi-Way 5 16th May 2006 07:45 AM
Monacor SPH 130 AL - anyone? andyjevans Multi-Way 10 8th December 2004 01:43 AM
Page generated in 0.07233 seconds (66.26% PHP - 33.74% MySQL) with 10 queries
