I was hoping to use a PHL 1310 in a 3 way active system with maybe a Hiquphon OWI and two 10 inch woofers for bass. XO frequencies would be at around 2-4kHz and 150-300 Hz both 24db/oct. I have been hearing good things about the PHL 1120 but the 1310 can play a little lower and is cheaper.
Has anyone heard this driver before? What should I use for bass 40-250hz? Many ppl have recommended some Lambda drivers but I dont think Lambda acoustics exists anymore. Id prefer quality midbass over deep extention. 10 inch drivers are preferred but I might go up to 12 inch. I need at least 7mm of excursion so I think most Pro audio speakers wouldn't work. Do you guys recommend any other tweeters? I will not be using a ribbon as I need better vertical offaxis performance. Thanks Alex |
#2 |
How much are you willing to pay?
#3 |
For the tweeter, Ill pay up to $125USD each.
For a pair of 10 inch drivers, up to $250. |
#4 |
Lambda drivers are now available through Acoustic Elegance/Stryke.
#5 |
Any recommendations for tweeters? Ive seen alot of ppl have used raven tweeters with PHL drivers. Is the vertical dispersion really that bad in those tweeters?
| Collated Design Criteria/dimensions for Ariel ML-TL Design | talsius | Full Range | 1 | 13th October 2011 05:28 AM |
| Wilson Watt Puppy Clone Design - Design Review Please | soundengine355 | Multi-Way | 8 | 15th August 2008 02:07 PM |
| Looking for: 1 radioshack supertweeter 40-1310 | zobsky | Swap Meet | 0 | 13th November 2007 03:10 PM |
| Duct Seal the Radio Shack 40-1310 ?? | Sam Odom | Multi-Way | 2 | 25th March 2006 10:00 PM |
| Page generated in 0.07519 seconds (81.24% PHP - 18.76% MySQL) with 10 queries |
