Old 9th February 2005, 11:17 PM   #1
Default Question about H/W/U-frame resonance
Regarding the resonance which occurs at a frequency whose wavelength is 1/4 of the length of the frame opening: is the resonance audible AT ALL if the response peak is equalized flat? i.e. would sound at that frequency decay much more slowly than other parts of the passband of the dipole woofer?
Old 10th February 2005, 12:55 AM   #2
Too late to edit the post, so change "audible" to "measurable/audible".
Old 10th February 2005, 11:50 PM   #3
Anybody?
Old 11th February 2005, 12:18 AM   #4
taloyd is offline taloyd  United States
Default MAD
hello,
try posting this question on the Madisound Audio Discussion forum:
http://madisound.com/cgi-bin/discuss.cgi
I'm sure JohnK and several others will jump on a chance to answer you...
cheers,
-tal
ps: (w-frame has the least usable range... H-frame has the most. So if you're looking to get midrange out of it, then there's no way a W-frame will work...)
Old 13th February 2005, 08:51 AM   #5
454
If the resonance is in your desired passband, you will be able to notch filter it satisfactorily *if components are available of the right value for the ‘centre’ and width of the resonance.
A friend tried to filter some very sharp driver resonances but the right value components were not availble. However if you look at eg the resonance of SL’s W baffle on his site, it’s very broad, and probably doable.
What passband were you after?
H frame vs W frame dipole woofers rick57 Multi-Way 18 8th October 2011 04:58 PM
how to calculate resonance in dipole H-frame? thadman Subwoofers 4 17th April 2007 08:10 PM
W-Frame or H-Frame dipoles? performace issues? JinMTVT Subwoofers 34 5th October 2006 04:44 PM
H frame/ Dipole/U frame ???????? j.burtt Multi-Way 24 1st May 2006 03:50 AM
Question re: Resonance in tall cabinets Ken C Multi-Way 6 4th September 2004 01:37 PM
Page generated in 0.07770 seconds (70.36% PHP - 29.64% MySQL) with 10 queries
