.. not Stereophile ranking or something.
A driver with dual windings, dc bias on both, letīs say 1A. The driver will still be in rest position and dissipate 12W for a 2x6ohm VC. We will more or less sidestep thermal compression but the cool thing is the VCīs could serve as load to a single class A device. Please, someone try this :-) /Peter |
#2 |
You might avoid additional thermal compression, but depending on the power spec. of the coils, you may have given yourself some right off the bat, giving the firstwatt the same compression as the twelfthwatt.
With a 1000W driver, the effect would be nil, but so I think would be the benefit. Not worth the effort IMO.
Jesus loves you. |
#3 |
The resistance will of course be higher than room temp but it will be constant so no thermal compression will occur as long as both devices conduct.
Thermal issues are only part of the idea, the fact that you can make a balanced Zen amp with coils as loads for the most simplistic amp/driver combo in history is cool IMO. ![]() /Peter |
#4 |
the best thing to do with a DVC driver is to use the second VC as a feedback generator ........ servo at it's best ......
| Grid bias with Class A SE ? | ThSpeakerDude88 | Tubes / Valves | 11 | 20th April 2008 05:01 PM |
| Inverting amp + Class A bias. is it possible or not? | Archwn | Chip Amps | 6 | 1st August 2007 02:53 PM |
| Class G Bias Questions | Randy Knutson | Solid State | 7 | 18th December 2004 02:28 PM |
| lm6172 class a bias? | crippledchicken | Parts | 0 | 3rd September 2004 04:33 AM |
| mmm.... zero-bias class B twin triode amp | Circlotron | Tubes / Valves | 6 | 5th March 2003 12:49 AM |
| Page generated in 1.79419 seconds (4.54% PHP - 95.46% MySQL) with 10 queries |
