Old 9th February 2005, 01:24 PM   #1
Default mic + pre
Hello.
What is better option for speakerworkshop ?
Behringer ECM8000 + Behringer Eurorack UB802 Mixer
or
WM 61A + diy mic
Where will be mesurmants more accurate?
Thanks for help.
Old 9th February 2005, 07:16 PM   #2
Shaun is offline Shaun  South Africa
Shaun's Avatar
Default About the same
Unless you get them calibrated. Then they'll be about the same.
For me the difference is that the Behringer setup is less susceptible to noise pickup, due to the balanced line. The mic looks more professional, too. DIY will be cheaper, though, with not much difference in performance. You can mod the Panasonic to have lower distortion and higher max SPL.
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
Old 10th February 2005, 06:50 AM   #3
I read somewere on diyaudio that ecm8000 can be calibrated in speakerworkshop but i cant find the topic.
Whad do i need for calibration?
Old 10th February 2005, 02:27 PM   #4
claudio is offline claudio  Italy
claudio's Avatar
To do a calibration you need a REFERENCE, thus another calibrated mic.
In SW you can give the program the calibration file, so that SW will use it for the acoustic response.
Claudio
Page generated in 0.07814 seconds (71.14% PHP - 28.86% MySQL) with 9 queries
