Old 9th February 2005, 05:05 AM   #1
Speakerholic
Cal Weldon's Avatar
Default I have an idea but I need advice about the 15” coax
If I mount them in the ceiling, at the end of the room, pointing downward from the attic, can I just spray them off a piece of wood placed in front of the driver, set at just the right angle to cover the room with sound?
I know it would have to extend below the ceiling for good coverage, that's OK, it's at the end of the room
I was wondering about the effect on the sound, it’s a PA driver and I’m not so sure it’s going to make that much of a difference. Is it likely to sound too much like a Bose system or should it be OK?
It's for when the friends are over and you want to crank up the Jimmy Buffet and dance a little. Those two and a 15" sonotube might just be the tiicket.
Cal
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 9th February 2005, 05:13 AM   #2
Stocker is offline Stocker  United States
Let me be the second one to get flamed by the members here (you being first) and say go for it.
For critical listening, use something else. For friends having a good time, good enough.
Jesus loves you.
Old 9th February 2005, 05:21 AM   #3
Send a message via MSN to darth_sanchez
ill third that. i seen some speakers that have the sound guides to project the sound from a different angle, not too sure how good the sound will be or how it will be affected, but i suppose you could give it a try, and if you like it, then keep it :P
Coax & DBR Thorsolar Multi-Way 4 14th July 2008 09:33 PM
An idea! Fully balanced TDA1541A DAC idea. Please comment! cartman Digital Source 8 17th July 2007 08:18 AM
need advice for my aleph 3 new idea ? jeapel Pass Labs 4 2nd March 2006 01:58 PM
Poster in Musical Instrument forum needs bridging advice on BrianGT 4780 advice moving_electron Chip Amps 0 16th February 2005 12:37 AM
hum from tv coax bonsai171 Everything Else 17 4th April 2004 05:25 PM
Page generated in 0.08609 seconds (73.45% PHP - 26.55% MySQL) with 10 queries
