hi there, i'm fishball79's friend described here chris (fishball79) made some speakers for me, the vifa p17/d25 bookshelves at audiodiycentral
i finally received my nad 3020e back from him and have been listening to the vifa bookshelves lately.. but after listening to these speakers they severly lack any bass extension. i did have a sub for it in a poorly designed box, but sold it off. chris now recommends using a peerless 8" woofer mated to a WES 200W plate amp im not too sure about adding in a sub as i had troubles integrating the old sub well with the bookshelves, but i think it was more to do with the box.. but yeah im not sure whether to add in a sub or make new speakers using the same drivers, as in Kai Stark's V3 MTMs or another floorstander design.. i don't have any complaints about the drivers as they are my first speakers, but there just isn't any bass. as mentioned in chris' thread the room isn't optimal, thin walls and glass windows on one side. the room is just my bedroom and the listening distance is extremely short, around 1 metre at most. here is a pic: ![]() i've been listening to alot of hip hop/rap lately so bass (high and mid) is quite important. i do listen other types of music, so i don't really want something boomy or peaky.. i guess if anyone can share their opinion, it would be greatly appreciated! thank you, peter |
#2 |
As the P17/D25-design only goes to about 80 Hz, you definitely need a sub if you want bass, but since the design also has quite smooth rolloff, you shouldn't have much difficulty in mating it to a sub
/U. |
#3 |
One possible option would be to convert the sealed boxes to floorstanding, ported ones, with a P17 you should get down to around 40hz or so....
#4 |
Pfft, iconic doesnt trust me!
I suggested a sub instead of increasing the box size due to several reasons. 1 - A seperate subwoofer would relieve the P17 of bass duties, thus improving midrange 2 - Seeing how messy and small his room is, having bookshelfs that can be placed in livable positions whereas a small subwoofer can be placed in the acoustically opimum positions 3 - He currently uses a 20w NAD, having a seperate sub with a subwoofer plate amp would also reduce the power requirements of the speakers and thus, again, improving sonics. What do you guys think? Chris
C h r i s |
#5 |
I agree with noodle_snacks and make a vented floorstander. I've heard the same drivers in a vented bookshelf of about 18 litres and the bass is not lacking at all.
A sub in there might be over the top. Oh, BTW, forget about the Peerless 8" for a sub unless it's the XLS 830491. Works well with music but it's not a HT rattler. |
#6 |
Account Disabled
I agree with all points made by fishball79.
AFAIK, John Kreskovsky designed it with the 80Hz 2nd order rolloff to assist with subwoofer integration. It certainly wasn't supposed to be a "full-range" loudspeaker. |
#7 |
Sub would probably be better in the end, but in the mean time it would only cost $50 - $60 to convert it to ported.
#8 |
thank you for the opinions. i think i might go for a sub.. i'm not too sure as my brother is moving out of the house, so i guess i might get a 'dedicated' listening room.. which means that i might upgrade the amplifier and thus speakers..
btw noodle_snacks do you have any schematics or links for a ported floorstander using the vifa drivers? thanks! |
#9 |
The old Loudspeaker Kit F6 MK1 used a P17 and D27 (very similar) in a floor stander.
Basically I think you could keep the same crossover. I would just download winISD and simulate your current cabs and then simulate some new ported boxes, basically you would be able to see the *rough* performance difference, don't forget because of driver differences the final cab wouldn't be exactly the same so you may want to tweak port length etc a bit. If you kept your original cabinets you would be able to change to a sub/sat system later or perhaps turn them into surrounds or similar. A quick search found this: P17WJ and D27TG into a floorstander-advice. |
| Vifa P17/D25 floorstander + XLS subwoofer finished! | tktran | Multi-Way | 14 | 26th July 2005 07:19 AM |
| Vifa subwoofer | rv1890 | Multi-Way | 6 | 14th February 2005 02:28 AM |
| Vifa XG18WH00-08 subwoofer? | audiokid25 | Subwoofers | 4 | 24th October 2004 03:15 PM |
| Vifa PLW for subwoofer | LarsAC | Subwoofers | 0 | 5th August 2004 10:37 AM |
| Page generated in 0.11515 seconds (76.32% PHP - 23.68% MySQL) with 10 queries |
