Old 9th February 2005, 10:37 PM   #21
GM is offline GM  United States
GM's Avatar
Do not know of a suitable HE mid driver with this much BW, but with a corrected ~96.4dB/W/m and 100W power handling, the Beyma 12CX combined with a suitable sub looks promising XO'd around 100Hz in ~27L sealed........ http://profesional.beyma.com/ENGLISH...p?pdf=12CX.pdf
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 9th February 2005, 11:25 PM   #22
To be honest, I'm not sure that picking up the tweeters was a great idea, in that you could probably have done a classic compression driver/pro woofer 2-way which would have been far simpler. The 3-way xover that you're now facing will be a much bigger challenge than a 2-way.
However, for a relatively cheap mid that is efficient and should be relatively decent look at the Ciare 6 or 8" ceramic drivers here:
http://www.assistanceaudio.com/08_Ciare.html . They're starting to get a bit ragged high up, so getting them up to 5-6k might be tight, but you'll be facing that with any driver. They're ~$40each, leaving you ~75/side for the woofers. (the 6" specs list a 92db efficiency, but the chart shows closer to 100 for most of the range. I'm not sure which to trust)
For the woofers, you'll have to look at pro drivers, as there is nothing in the 'hi-fi'
realm that will be anywhere close to the efficiency you need. Basically, get the best pro 15" you can afford, and put it in a big box tuned with an EBS alignment. You should get decent extension to ~40Hz with this. (Selenium 15PW3CE from PartsExpress looks pretty good - unlikely you'll do much better for the $)
Old 9th February 2005, 11:27 PM   #23
D'oh! Thanks for mentioning Bills stuff, Jim - I fogot about it.
Actually, just going for the David might not be a bad idea, either - a bit more $$$ than the line arrays, but still doable.
Old 10th February 2005, 12:05 AM   #24
DonoMan is offline DonoMan  United States
Send a message via AIM to DonoMan
I've decided to try a Beta 10 + 2 Peerless MF 122 + those tweets
I only ordered the drivers for 1 speaker, so it won't be too bad if they don't work so well together. I may need to attenuate the tweets a dB or 2, but I'll wait and see how they work when I get them.
The reason I got planar tweets is because my friend keeps telling me they sound so much better... If they're not my thing, not much wasted, ya know?
Old 10th February 2005, 02:15 AM   #25
Banned
The Beta 10 is quite good actually, but you do have to use a 5.5 cu ft box. At half the price an MCM 55-2421 in a Tuba 18 beats it quite handily in 3.3 cu ft box, but you do need to corner load it. David w/the same driver also beats the Beta 10 without boundary loading in a floorstanding package, but it might be a bit much for a newbie builder.
Old 10th February 2005, 02:58 AM   #26
Oh, I will be getting a sub soon enough.
High sensitivity Loudspeaker Lutz_RE Multi-Way 4 6th March 2008 06:52 PM
What is better: low or high sensitivity microphones ? Web Wolf Multi-Way 4 7th May 2006 10:35 PM
high sensitivity 2way rebojorge Multi-Way 15 22nd April 2004 06:08 PM
High Sensitivity drivers...Where? EngelholmAudio Multi-Way 28 30th April 2002 02:11 AM
Copyright ©1999-2013 diyAudio
