Old 8th February 2005, 03:17 PM   #1
Grahamt is offline Grahamt  Canada
Grahamt's Avatar
Default Extremis MT cabinets done (pics)
Here is one of my MTs. They are 34L tuned to 25 Hz. They are about 10" by 17" by 21". They are made from .75" ply and 1.25" butcher block. I have some AutoCAD drawings if anyone is interested in the construction. The finish is spray on truck bed liner, a very forgiving, durable finish.
The tweeter is the LPG 26T and the woofer is the Adire Extremis 6.8. In my room these are as loud at 20 Hz as they are above 100 Hz.
The crossover isn't done yet. A friend is working on it in his spare time. It will be a 4th order Linkwitz Riley with cauer elliptic filters bringing the attenuation to about 8th order and crossed over below 1.5 kHz IIRC.
Old 8th February 2005, 03:18 PM   #2
Grahamt's Avatar
More pics
Old 8th February 2005, 03:20 PM   #3
Grahamt's Avatar
Side
Old 8th February 2005, 03:21 PM   #4
Taco is offline Taco  Netherlands
Wow, that tweeter looks like if it is modified. The top-end of those Extremis woofers are not that nice, so I think an x-over of 1500Hz is a good starting point. Also that cabinet looks deep.
Old 8th February 2005, 03:21 PM   #5
Grahamt's Avatar
Back
Old 8th February 2005, 03:23 PM   #6
Grahamt's Avatar
Yep. It is modified using the JonMarsh method. Stuffed the pole piece and centered the voice coil.
The cabinet is deep to get the low frequency efficiency and to allow for a port long enough. The 2" port I used is about 12" long, and a 3" port that I may use would be close to 16" long IIRC. Also there will be hardly any reflections off the back wall of the enclosure.
Old 8th February 2005, 03:49 PM   #7
gary f is offline gary f  Canada
gary f's Avatar
I think the 26T tweeter don'T have a good reputation for low crossovers below 3000 Hz. The X max is 0mm because the voice coil is the same length as the gap so don'T expect it to play low.
F
Old 8th February 2005, 04:06 PM   #8
Grahamt's Avatar
According to the crossover designer, the low crossover point should be okay because the attenuation is so high. He is doing distortion tests on them to see how low we can go. Hopefully the modifications will help.
Here is an example of the crossover.
Old 12th February 2005, 11:45 AM   #9
Radian is offline Radian  Germany
Question LPG tweeter
Hello Graham,
How is the sound of the modified LPG?
The 25FA was used in the highly regarted Silverline Sonatina I +II.
Solen has them for $17 on sale and I am really tempted to try them out.
But if the version you are using is better I will spend the extra $$.
Klaus
Old 12th February 2005, 12:06 PM   #10
Grahamt's Avatar
Hi Klaus,
I have not listened to the tweeter much since the crossover is not done. From the little listening I have done, they sound pretty good. If you want see the mod thread here it is:
http://htguide.com/forum/showthread.php4?t=11305
Sorry I could not be of more help. When the crossover is done I will know more.
Looking for Extremis 6.8 nelsondog Swap Meet 0 13th October 2007 01:41 AM
pics of my fostex fe126e cabinets for dayton/pyle drivers Binkstir Full Range 15 27th December 2006 10:20 PM
Extremis Usher project prelim pics LukasLouw Multi-Way 8 17th September 2006 12:57 AM
WTB: Extremis 6.8s kestrel200 Swap Meet 10 5th March 2006 02:06 AM
extremis bser Multi-Way 1 9th January 2005 09:21 PM
Page generated in 0.10762 seconds (77.55% PHP - 22.45% MySQL) with 11 queries
