Old 8th February 2005, 05:28 AM   #1
andy2 is offline andy2  United States
Default Does this device make sense for speaker design
Do you think this would be helpful in speaker design? Or is there such a device out there already?
How about if there is a DSP instrument which can emulate most type of filters that would usually go into the xover? The software would allow you to sellect different type of filter.
Think of it as a black box active xover that sits between your preamp or cdp and the amplifier. The output of the amplifier would then be connected straight to the driver without going to a xover. During the designing process, instead of designing the xover from various discrete parts, you can play with the DSP black box and fine-tune the filters on-the-flight through a GUI from a computer.
This blackbox DSP for example would have 3 outputs per channel: one for tweeter, one for midrange, and one for the woofer. Each output is independent of each other and can have its own filter. As for input, it would have a digital input to interface directly to the digital output of the transport. It would also have an analog input so that you can connect it to a preamp.
Of course this would only help at the initial stage to give you some idea how each drivers would behave roughly. You still have to deal with other effect of a real xover and how they all interact with the amp and all that such as having a conjugate load or a zobel network. One way is to have the conjugate load or zobel network but the filter will be implemented on the DSP box. You then would just sit at your computer and play with different type of filter.
Old 8th February 2005, 10:54 AM   #2
paulhfx is offline paulhfx  Canada
What you've described is part of the emulation software within LSPCad 6.
I haven't used it yet, so I can't comment on how well it works or how easy it is to use.
Paul
Old 8th February 2005, 11:18 AM   #3
Brett's Avatar
Sounds like a Behringer DCX2496
Old 8th February 2005, 02:35 PM   #4
Nappylady's Avatar
Send a message via ICQ to Nappylady Send a message via AIM to Nappylady Send a message via MSN to Nappylady Send a message via Yahoo to Nappylady
Or a Soundblaster Live! running with kX drivers
Old 8th February 2005, 09:20 PM   #5
bzdang is offline bzdang  Canada
bzdang's Avatar
Kxproject !
(caution: you may never finish the passive crossovers )
Benford's law of controversy - Passion is inversely proportional to the amount of real information available.
Old 8th February 2005, 11:12 PM   #6
RobWells's Avatar
Certainly does. I never moved on to 'custom built active xo's' after using this item. (would of been op-amp based if I'd gone there btw)
Rob
Old 9th February 2005, 12:32 AM   #7
Brett's Avatar
Originally posted by bzdang
Kxproject !
Now this is going to sound dumb, but what are KX drivers? Do they allow you to use the PC+SB5.1 card to sim a xover? How many channels and xover ways? Delays too? Where do you get the software? URLs?
I've been contemplating a DCX2496 for the horns I'm playing with, but it's a bit expensive over here, and a cheap, ie the cost of an SB card, project is intriquing. If I could get it to work to my satisfaction with this, cheaply, then the DCX may be a worthwhile purchase.
Old 9th February 2005, 12:43 AM   #8
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
I see the Behringer DCX2496 online some places now for $250!!
now that's cheap! Either a new model coming out , or they have made so many that their unit cost has plunged!
Old 9th February 2005, 01:01 AM   #9
bzdang's Avatar
Variac, they have mastered the art of China-procurement.
Brett, I will answer any questions that I able able to, but please search for and read my other posts first, there is some kxproject information in them already
Some recommendations to keep in mind --
- it's possible to purchase a wrong soundblaster card, do homework first!
- practice on woofers first
-it's possible to kill tweeters and compression drivers with low freqs, always check your setup and use a cap. to protect them.
- to avoid loud surprises, run the computer audio at maximum non-clipping levels and set your pwramp levels externally
- current version is 3537, don't get 3538 yet, is beta.
- get the ufx plugins for 3537
- I have the simple delay plugin if you can't find it, ask and I'll mail it
Dave
Old 9th February 2005, 01:09 AM   #10
tiroth is offline tiroth  United States
Wow, the DCX is now cheaper than the DEQ!
Linear voltage regulator: how to make good use of "sense" and "ground sense"? NeoY2k Analog Line Level 7 6th September 2008 11:35 PM
TL, does this now make sense? Madmike2 Multi-Way 2 8th May 2005 02:39 PM
Does this make sense ? 00940 Solid State 7 27th March 2004 09:29 PM
does this make sense? nosegoblin Solid State 9 14th February 2004 02:19 PM
Does this make sense? Illusus Chip Amps 11 25th September 2003 01:59 PM
Page generated in 0.10663 seconds (79.82% PHP - 20.18% MySQL) with 11 queries
