Old 7th February 2005, 02:14 PM   #1
Audist is offline Audist  United States
Question what the max Air velocity of bass reflex port?
Dear all,
What the good Air velocity for the bass reflex pip port? 5 m/s peak is okay? have a problem with this?
What the maximum? I read in some website "keep less from 17 m/s". Is truth?
Old 7th February 2005, 06:33 PM   #2
Ron E is offline Ron E  United States
Ron E's Avatar
Lower is always better, but 17m/s is often given as a practical maximum value. Once the port diameter equals the driver diameter, you probably wouldn't gain much by increasing port diameter. Basically , port size is a compromise based on what you can fit into a box. If you can't fit a large enough diameter port, you need to either live with port noise or use a PR. Flaring both ends of the port can help a great deal, BTW.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 7th February 2005, 07:31 PM   #3
Thank you very much,
My port show 4.5 m/s in peak, even a little less...
My question if the diameter not less from 5 cm (internal) for the port, and the Air velocity is 4.5 m/s or 5 m/s peak. I can hear the port noise?
Old 7th February 2005, 07:39 PM   #4
simon5 is offline simon5  Canada
You will not hear it.
DIYaudio for President !
Old 7th February 2005, 09:43 PM   #5
Ron E's Avatar
At what power level are you seeing 4.5 m/s?
IF you never plan to use above that power level, you are probably OK. Safest thing is to post your entire design so that errors in input, etc can be checked; but if you are confident you made none and that whatever program you used is correct, you are probably safe.
As a rule of thumb, a 5cm port should typically be safe up to 17cm driver and 7.5cm port up to a low excursion 25cm driver. Above that, you may need one or more 10cm ports.
Bass Reflex port for Usher 701 kit nippontiger Multi-Way 7 16th September 2008 04:11 PM
Bass reflex port question Javachip Multi-Way 12 11th April 2006 01:11 PM
Tuning bass reflex port beamnet Multi-Way 0 28th September 2005 02:03 PM
Port location in a bass reflex box quasi Multi-Way 24 30th April 2005 04:53 AM
Q-factor of bass reflex port SSassen Multi-Way 6 26th March 2005 09:26 PM
Page generated in 0.09959 seconds (69.11% PHP - 30.89% MySQL) with 10 queries
