Old 6th February 2005, 09:20 AM   #1
Tyimo is offline Tyimo  Hungary
Default TML suggestions
Hi!
I would like to build a TML speaker with this fullrange driver:
Fs: 59 Hz
Sd: 132 cm2
Re: 6.2 Ohm
Qt: 0.367
Vas: 20.63
Bl: 6.83
Qe: 0.43
Qm: 2.51
Well, I would like to please the TML experts to suggesting me what kind of cabinet would be ideal for this driver?
My initial specification:
-to go so deep as possible
-to get the best transient response
I attached 2 simulations: a TML and a ML-TL, but I don't know wich would give me better result in the reality? I mean: may be the ML-TL could be slightly boomy with room gain? The TL has a gentle roll-off could be work better with the room gain? I know classical BR and TL speakers, but I don't know how is sounding a ML-TL? Has it so nice transient response as a classical TL?
Waiting for your oppinions and help:
Tyimo
Old 6th February 2005, 05:49 PM   #2
GM is offline GM  United States
GM's Avatar
What driver?
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 6th February 2005, 08:20 PM   #3
Timn8ter's Avatar
Originally posted by GM
What driver?
GM
Good question. My initial reaction is that neither one is correct for this driver. A tapered line may be a better choice or even a horn. Your quest for bass response may lead to a "thin" sounding speaker.
Old 7th February 2005, 05:24 PM   #4
HI!
GM: It is a unknown (hungarian) fulrange driver. Made in a small manufacture. I should say a kind of "Fostex replica".
But what is with my question about the transient response?
Has the ML-TL similar sound than a TML?
Any suggestions????
Tyimo
Old 7th February 2005, 09:50 PM   #5
GM's Avatar
Greets!
OK then, I assume it will not have much linear excursion. This means the better transient response (TR) of the TL due to its gradual roll off will severely restrict LF (and probably midbass) output so either you will have to attenuate the signal below ~80-100Hz and/or only listen at very moderate SPL, otherwise the increased harmonic distortion will make it sound worse than the higher group delay ML-TL, though it will still be somewhat better than a BR.
WRT sonic differences, beyond the ML-TL having much greater gain that will interact with the room more, there's not much, if any, audible difference and why of the two, I recommend the ML-TL and increase the vent length to lower Fp if there's any room 'boom'.
WRT 'best' TR combined with the lowest extension, this means either a very large sealed cab or a more traditional stuffed pipe to mimic one in a smaller package, so either a ~206.3L sealed cab or an end loaded Alpha TL ~53.27" long with a ~103.502"^2 cross sectional area (CSA) stuffed with 1.551lbs/ft^3 of polyfil.
GM
Old 8th February 2005, 05:00 PM   #6
Hi GM!
Thanks a lot!
Do you realy say that I should/could go lower with this driver in a ML-TL? I thought it is not recommended to go much more deeper than the driver Fs and I thought it is already over tuned too.
So, with the ML-TL I would get similar sound then with a TL?
Super! I like it. :-)
Another 2 question:
-is there any dB gain, if I would paraleling 2 driver, but with different dB? I mean one has 87 and the other has 92?
-could you tell me where can I find infos about the original B&W Nautilus closed TML speaker?
Thanks and greets:
Tyimo
Old 8th February 2005, 08:38 PM   #7
GM's Avatar
You're welcome!
No, I am saying you can tune the ML-TL as required to better blend into the room gain, if any. In this respect it is much more flexible than the TL.
Correct, if tuned to the TL's low Fb, I doubt you will be able to tell whether one or the other sounds better.
Yes there will be some gain, though it will be based on their combined cone area, not their reference sensitivity.
No, I do not keep up with consumer designs. I do recall a website that detailed the crafting of a clone though, so maybe you can find it in a search.
GM
Old 9th February 2005, 04:57 PM   #8
Hi GM!
Thanks!!!
Greets:
Tyimo
Old 9th February 2005, 08:01 PM   #9
GM's Avatar
Greets!
You are welcome! Let us know what you build and how they sound.
GM
Old 1st March 2005, 04:41 PM   #10
Hi!
I have an another driver what is good for closed-sealed speaker, so I would like to ask:
Is there any rule of thumbs how to design a good closed end TML speaker?
Greets:
Tyimo
First DIY. Suggestions are welcome. RomanSivers Multi-Way 3 19th December 2006 04:29 PM
SET Suggestions nogoodboyo Tubes / Valves 37 11th March 2006 08:38 AM
need suggestions please.. oface Full Range 2 23rd March 2005 04:46 AM
DAC Mod Suggestions? Flappytango Digital Source 24 4th February 2004 04:25 PM
Any suggestions jaybird Multi-Way 3 15th January 2004 09:12 PM
Page generated in 0.11567 seconds (86.14% PHP - 13.86% MySQL) with 11 queries
