Basically I want to know what brand speaker drivers (for home theatre) are total ****, decent (mid-range) and top of the line and how much they are going to set me back? I've got some really nice enclosures and would just like a general idea about drivers. Thanks for any help!
PS. I'm a bit of a n00b so please keep it a bit simple |
#2 |
Bazooka,
Speakers are a "system" comprising of enclosure, driver and crossover. for the system to work properly, it must be designed so that the enclosure, crossover and driver work well together. "Really nice enclosures" with incompatable "top of the line" drivers and an incompatable crossover will sound poor. A great point to start from would be to see what drivers and crossovers the enclosures are designed for and then build that. Otherwise, a little trolling on this forum will provide some links to kits where someone has already done the hard work of integrating compatable components. Now, before getting too far ahead of yourself, if you are asking for advice here, the things people will need to know are: What will the system be used for (I assume that for you this is home cinema). What amplifier are you using, and what is its output (watts) What is your listening environment (what size room etc) This link is to an Australian speaker kit manufacturer. Some good advice on the home page and will give you an idea of what is available. http://www.theloudspeakerkit.com/ind...?page=whichkit Good luck with the research and the eventual project Cheers, Chris |
#3 |
| speaker burn in using lg mini home theatre? | milen007 | Multi-Way | 5 | 6th June 2008 05:54 AM |
| Low cost coaxial drivers for home theatre | arjscott | Multi-Way | 5 | 14th June 2006 05:03 PM |
| Which drivers for home theatre?? | HTRookie | Multi-Way | 1 | 23rd January 2004 10:16 AM |
| car or PA or home theatre drivers | Kilowatt | Multi-Way | 12 | 1st May 2002 04:36 AM |
| Vifa Car Drivers for Home Theatre Project? | needle | Multi-Way | 0 | 24th April 2002 02:41 AM |
| Page generated in 0.07388 seconds (68.55% PHP - 31.45% MySQL) with 10 queries |
