Hoping someone can suggest a solution to my dilemma. I made driver cutouts for some TB 871s, and upon putting one driver in one of the holes, I found that the cotout was the right size, but the inner 'shelf' that the driver sits on and the screws actually bite into is too narrow, so that it doesnt completely cover where the screws will go.
In other words, if I look at the driver straight on, I see some mdf and some air through the screw holes. Surely this has happened to someone else before? Any suggestions on how I can mount these drivers without the screws (with aesthetics in mind) would be hugely appreciated. |
#2 |
Perhaps you could rebuild the shelf with something like car body filler?
https://mrevil.asvachin.eu/ |
#3 |
Just glue blocks behind where the screws go.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#4 |
Why dont you try this:
http://www.diyaudio.com/forums/showt...7122#post97122 And some filler to make it airtight. |
#5 |
thanks for the suggestions.. I am a little limited in what I can do as the box is already glued together and I have access to the interior only through the driver cutout, so as elegant as the knuts are, I don't think I will be able to install the interior screw for them. So far the blocks option looks most likely, I am going to have to think about it a little.
#6 | |
#7 |
The blocks sound ok... but the choice of material is important, since your screw seems likely to go right through the glue joint...
so, I'd pre drill the hole before placing screws. The other possibility is clamping the drivers, you still need to fill the holes but you can do that with something like "Mortite" window putty - a good non hardening (well not super hardening) material to make air tight gasket mounting of speakers.... If ur really industrious and have a good drill press and a circle cutter (fly cutter type) you could actually cut rings to fit into the hole, if you are careful... alternative (2) (better) is to make a cut out that fits with a little sanding into the holes you cut, glue that in and then redrill the cutout to the right size. (you get the new plug piece flush by laying it in screwed to a bit of flat stock... (a hockey puck screwed to a 2x4, in concept) Plan(3) make a new baffle that sits on the old baffle, but has a taper or curve from the driver cutout back to the edge of the baffle (or an appropriate distance. You can completely cut out the hole area that now exists, assuming multiple drivers, so there is less or no cavity created behind the driver... etc... Btw, non-flat baffles (curved or tapered) often have better looking freq response than do flat baffles with a sharp edge... _-_-bear PS rule #1 for mounting drivers - always do a test cut on scrap and see if it fits before cutting on the finished piece(s) !
_-_-bear http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. -- |
#8 |
Try to get back to the point you were at before you did the cut-out(!).
Yes, I'm talking about cutting a complimentary wooden plug, then glueing it back in there. All you'd have to do is measure the actual size of the rebate (diameter and depth) and the cutout. This is of course assuming that you have a regular circular cutout, as one would achieve when using a circle jig. It's not critical, but this would make for the neatest repair. HTH
Shaun Onverwacht |||||||||| DON'T PANIC |||||||||| |
#9 | |
Then again, lots of people like having double thick front baffles. Cut your existing hole just a little bit larger then glue on another baffle with the correct cut out for your driver. Try to get the two holes to match up and have a nice taper. |
#10 |
If you can get some thick [non-dripping] epoxy adhesive then the block approach might be easiest to do. CanTire or a marina store [in Guelph?!].
Benford's law of controversy - Passion is inversely proportional to the amount of real information available. |
| what size box will be best for this driver ? | zuki | Multi-Way | 9 | 5th April 2007 02:22 PM |
| two BIB questions re inner baffle and driver cutout | drec | Full Range | 3 | 23rd December 2006 02:59 AM |
| What went wrong with my amp? Bass driver strange movement. | chengs | Tubes / Valves | 10 | 20th October 2006 02:19 PM |
| Driver Size Thoughts | theNoid | Multi-Way | 9 | 11th September 2005 04:05 PM |
| Page generated in 0.12209 seconds (77.47% PHP - 22.53% MySQL) with 11 queries |
