I am considering building a speaker system and after having read quite a few discussions I am left with these two projects:
Seas Thor ProAc 2.5 Clone I mosly listen to Jazz, Pop, Rock + some classical. The room is quite large, about 55 m2. I have a moderate 60W transistor amplifyer, but am also considering to upgrade this to a more powerful power amp. I know that the Thor is quite a bit more expensive, but due to the size of the room, should I go for the TMT Thor instead of the smaller ProAc? Thanks for input! -Thomap- |
#2 |
Account Disabled
The tradeoff for great bass of the ProAc Response 2.5 and clone is the speaker's relatively low sensitivity. I have my ProAc clones in a medium-large 6x9(54m^2)x2.7m living room, which opens into a kitchen. I use 90Wx2 which is loud enough for many people, but it does not reach lifelike/live levels without. When pushed hard is sounds constrained or compressed. A single 7" woofer can only do so much. I much prefer my ProAclone in our smaller formal dining room. (~30m^2) Based on higher sensitivity and power handling alone, I would recommend the Thor for larger rooms. I have not heard the Thor, but fortunately, they are great on almost all accounts. |
#3 |
Hi thomap,
Hi tktran I found someone who use Seas Thor. He told me that Thor has a great sound. It has natural, detail bass and could go deep as he want but slightly lean. I'm trying to set schedule to visit him and I will brough Pink Floy, The Eagles, and some fusion jazz CDs to test the Thor. I'll post my review after that. Regards Santi |
#4 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#5 | |
Where can I get a corrected plan? Santi |
#6 | |
frugal-phile(tm)
You'd be even better off to just optimize a line using Martin king's software... i'm also of the opion (completely unfounded on anything but my experienced conjecture) that the drivers would be better in a 2.5 way with the 0.5 driver mounted push-push wrt to the midbass that reache sup to the tweeter. Some rework of the XO would be required thou. dave
#7 |
I am trying to make the same decision so will appreciate any comments on the forum. I will be using an aragon preamp/amp or if part of my home theater a Harmon Kardon 70w receiver. Seems like SS amps might be a problem with the Proac.
Comments from you DIY'ers? Thanks in advance |
#8 |
Thomap
I had listen to Seas Thor last weekend. The result is same as i mention above (lean bass). I think this speaker is good for acoustic music, vocal, not for pop, rock, orchrestra. regard, santi |
#9 | |
regards
"The only thing neccesary for triumph of evil is for good men to do nothing" -Edmund Burke |
#10 | |
frugal-phile(tm)
dave
| Seas Thor vs Seas Excellence | phillfyspoon | Multi-Way | 1 | 31st March 2007 07:24 PM |
| seas thor?? | twenty | Multi-Way | 8 | 20th August 2006 12:22 PM |
| Thor Clone? | bhg41088 | Multi-Way | 0 | 11th November 2004 04:27 AM |
| Question regarding ProAc 2.5 Clone and Tempo 2 Clone | zoooh | Multi-Way | 5 | 11th March 2003 08:19 PM |
| Page generated in 0.11609 seconds (81.77% PHP - 18.23% MySQL) with 10 queries |
